i got a 525 oil pan at the yard and
  • KillaCam
    • 2103
    you know that thing that goes on first to hold up oil for the crankshaft. well i always see them for sale and it is detachable from the pan and the pan i got it is attached. is that bad? does it matter?
    Originally posted by E30_(1st Musk)_
    HONDA IS WHERE EVERY TREND DIES! .
    24v swap Oil Pan..F/S
  • hfabricius
    • 608
    The one attached to the block is used for the e36 pan with the rear sump. The one in the e34 pan is all that you need if I understand all my info correctly. I just removed the one that was attached to my engine and utilize the one in the e34 pan since I got my M50 out of an e36.
    http://halden-fabricius.tumblr.com/
    • SkorcherX
      • Jun 2011
      • 267
      I second this info.
      • Thrizzle
        • Aug 2011
        • 194
        I just left the piece in the e34 pan, and removed the one on my s52.
        • treff-7
          • Sep 2009
          • 345
          The pan i got off of a 525 didn't have it. is that normal or i managed to get a junk? i installed it with no problem and left the original one on the s52 block.
          • KillaCam
            • 2103
            i think you're good.
            from what I'm gathering i think they made 2 styles. ones with the oil keeper upper thing attached and not attached
            • treff-7
              • Sep 2009
              • 345
              ok, thanks! now i'm second guessing every part i got for my swap. i just found out that the e36m3 drive shaft i bought is for an auto when i asked for a manual. i bought it like 2 months ago. i hope they will be nice and swap it out for me! it was their f**k up so they should...
              • jrdeamicis
                • Nov 2008
                • 956
                This just means you need to get a 6 speed.
                Past Car : E30 S50 6 Speed 5 Lug 3.73
                Current : Z3 S50 OBD2 (Smog Legal) 6 Speed BBS RN Dual Ear Diff
                ___________________________________________
                BNB Designs
                Engine Swaps, Fabrication, Innovation, General Repair
                Richmond CA
                Julian 848-248-8029
                • treff-7
                  • Sep 2009
                  • 345
                  i wish! baby is coming any day now. no more fund for the swap so i have to work with whatever i have. it would be awesome though! i still want a bbk but i will try to get the money for it by selling all the parts i don't need.
                  how much does the 6 speed go for BTW? the auto drive shaft would work with that?
                  • jrdeamicis
                    • Nov 2008
                    • 956
                    yes. An auto E36 328 shaft would work for your 6 speed.
                    The 6 speed is around 1k-1.5k, the flywheel can be between $100 and $800 (used to new)
                    There is a few other costs.
                    BNB Designs
                    Richmond CA
                    Julian 848-248-8029
                      • 34844
                      oil keeper upper thing? lol? are you guys talking about the windage tray? you'd be better off using it than not.
