E36 M3 radiator?
  • M///BMW
    • 216
    E36 M3 radiator?
    I am in the process of purchasing a radiator and was just about to purchase a OEM E36 M3 radiator and came across this on Ebay. I know many people can't stand ebay parts but from the looks it seems to be a quality product.
    http://www.ebay.com/itm/92-99-BMW-E3...ht_4122wt_1396
    http://www.ebay.com/itm/BMW-1992-199...ht_3989wt_1163
    What are your thoughts?
  • ak-
    • 12422
    Hit and miss with eBay. Usually the technical/mechanical things for sale are what's a miss.
    Example:
    Most turbo's, BOV's, wastegates = garbage
    Cheap intercoolers = win.
    I'd probably purchase it. It's just a radiator. Simple organ.
    1991 325iS turbo
    • M///BMW
      • 216
      Example:
      Okay. This is exactly what I have come up with as well.
      Has anyone run one of these?
      • 325issguy
        • Dec 2005
        • 261
        Wouldnt trust the vital cooling piece on ebay quality but thats just me.
        Also, a simple search would reveal that you cannot use the e36 radiator in an e30. Alot of people are running the m42 radiator.
        • Jand3rson
          • 37587
          M42 is the way to go, depending on your climate.
          Up here in the mountains, I get away with it just fine. Dry heat and hardly any humidity, when it actually does get hot enough to matter.
          In Florida, I don't know if the M42 would cut it, might not have enough cooling capacity.
          • Adrian_Visser
            • Jun 2006
            • 2823
            Maybe you should do a simple search noob, the late model e30 and e36 rads are the same.
            '89 Alpine S52 with goodies
            • Eric
              • 5142
              I'm running a 3 core S54 M coupe radiator. Go OE with important items like cooling.
              • Adrian_Visser
                • Jun 2006
                • 2823
                What's the space between engine and rad like with the s54 rad?
                • 325e10
                  • 161
                  http://www.ebay.com/itm/BMW-92-99-E3...item2a12cc1bb4
                  I'm using this radiator and so are 2 of my buddies. Works great
                  • cormier
                    • 380
                    Curious as well, any pictures?
                    • Eric
                      • 5142
                      I'll grab some pictures, but it's about an inch I'd say. I'm running a euro S50 though, so it might be a bit different. Also running the AKG motor mounts.
                      • ak-
                        • 12422
                        que
                        1991 325iS turbo
                        • M///BMW
                          • 216
                          What did you do as far as the expansion tank?
                            • 34844
                            what?
                            • JFarhanbod
                              • 2151
                              this is the radiator that im planning on using. how long have you and your friends been using it?
