Well Beej's thread got me thinking that something isn't wired up/working right in my swap. Time and time again I have been checking for vacuum leaks, faulty sensors and the works only to be struck down and basically put back to square one. Lolcantturn asked me to check if my VSS is functioning properly, procedure was to speed the car up to say 25-35mph and coast in neutral to see if the idle rises to ~1,000rpm, once car comes to a standstill, idle should drop back down to normal. I proceeded to do this test and when the car was cold not much happened, idle never "rose" to the desired 1,000rpm but stayed at a regular idle which to me seems a bit low, once the car warmed up, the car would surge and hunt for idle until I would come to a standstill and finally idle would return to normal, Here is a video of what I am talking about, I let the car coast from about 35mph to a standstill and see for yourself what is going on.
Input?
Input?
