Hunting for idle when coasting, VSS related?
  • lolcantturn
    • 4588
    #46
    Originally posted by Beej '86 325es
    I'll have to check and see if mine does that too.
    I noticed the fuel consumption wire that feeds the economy gauge also goes through the DME. I found that mine was not connected at all.
    Any chance that would affect engine running?
    mine no worky either.
    Originally posted by TSI
    OEM+
    • trackjunkie21
      • Jan 2010
      • 3962
      #47
      Is this what makes the gauge actually work? Mines working and reading well it seems.
      Originally posted by Wh33lhop
      VANOS: sometimes you just need to go full retard.
      • lolcantturn
        • 4588
        #48
        bump
        OEM+
        • e30rapidic
          • 2167
          #49
          87 325i/e34 harness/413 red DME
          Mine runs like a fucking champ, never hunts for idle. Pin 42 gets its speed signal from the green plug on the back of the cluster.
          I know you guys don't have a C104 but maybe this will help to get your econometer working (although it won't be accurate)
          DME Pin 24 on mine goes to the c104
          DME Pin 14 on mine goes to the black wire of the c104
          plus - how old are your vacuum hoses???? reusing old hoses is like reusing gaskets....may work but probably won't
          '87 325ic, powered by S50.
          • 328ijunkie
            • May 2007
            • 3961
            #50
            Ive also never had this issue on any of my or my customer cars...
            Check Us out on Facebook
            Full Product Line Tuning
            • lolcantturn
              • 4588
              #51
              Hear that folks? E34 harness! All us guys with problems have E36 harness's! Im not going crazy! Never had this issue with my last swap car and it was exactly the same setup and pinout chart as my current one which has an E36 harness!
              Econogaug did work on my last swap car too :(
              OEM+
              • 328ijunkie
                • May 2007
                • 3961
                #52
                I always use E36 harnesses....
                • trackjunkie21
                  • Jan 2010
                  • 3962
                  #53
                  I find it hard to believe it's because of using the e36 harness, maybe coincidence?
                  • Beej '86 325es
                    • 2639
                    #54
                    Being that I've timed the issue on my car to start running correctly after 8:45 to 9:00 minutes 5 times, this leads me to believe it's a sensor problem somewhere.
                    ...too coincidental for vacuum leaks or burnt up wiring...UNLESS the DME is programmed to ignore the problem after a certain time.
                    -Brandon
                    '86 325es S50
                    '12 VW GTI Autobahn DSG
                    '03 540i M-Sport (sold)
                    '08 Jeep SRT-8 (sold)
                    For sale:
                    S50 TMS chip for Schricks
                    • trackjunkie21
                      • Jan 2010
                      • 3962
                      #55
                      I should check my 02 sensor, should I check at the 02 sensor plug? Or at the relay?
                      • Beej '86 325es
                        • 2639
                        #56
                        I checked mine at the engine side of the O2 plug (peel back the boot). Check for voltage at between the BRN and GRN wires.
                        You can also check for voltage at the socket for the 30 prong of the relay. I'm not sure if it matters if the relay is plugged in or not though. I guess you could jam in a wire with the relay plugged in like I have at times for testing.
                        -Brandon
                        '86 325es S50
                        For sale:
                        • trackjunkie21
                          • Jan 2010
                          • 3962
                          #57
                          Was going to check today but I forgot I did install a new ICV and that did nothing :(
                          • Beej '86 325es
                            • 2639
                            #58
                            Sorry to hear that...
                            Those of you with E36 harnesses, was your harness from an auto or manual?
                            Mine was an auto and I stripped out the wires.
                            -Brandon
                            '86 325es S50
                            For sale:
                            • lolcantturn
                              • 4588
                              #59
                              Manual harness.
                              OEM+
                              • lolcantturn
                                • 4588
                                #60
                                Bought an E34 manual harness from 328ijunkie...I'm going to put an end to all of this. If my car has the same problem, well, may god help us all.
                                OEM+
