E30 M3 wire Covers, on S/M50 UPDATE
  • Beej '86 325es
    • 2639
    Originally posted by janderson
    i probably used almost 2 dozen, and just crammed down every wire as tight as i could (without damaging them, of course). Just go slowly and carefully, you can get them all to fit, and not a single one of mine is ran outside the covers.
    +1
    -Brandon
    '86 325es S50
    '12 VW GTI Autobahn DSG
    '03 540i M-Sport (sold)
    '08 Jeep SRT-8 (sold)
    For sale:
    S50 TMS chip for Schricks
    • Den_k321
      • 1248
      so far its working! its looking good from the ecu all the way till little passed the middle,
      my second question, Im using an adapter that NANDO made [ looks good will show pictures]
      Whats the best way to fit the adapter? since it would never fit under/inside the cover...
      [i know lots of you dont have adapters, but for now i will have to use it...]
      1988 325is S50 in-progress.
      http://www.facebook.com/E30LocalCrew
      Few pictures:
      http://www.r3vlimited.com/board/showthread.php?t=255061
      • Dj Syco
        • 382
        I'd go different from the zip ties and use electrical tape. easier to compact stuff and looks cleaner if you have to take the cover off. as for the adapter, place the engine side in the holder(doesn't fit perfect, hole is too big) and just try to make it look as pretty as possible. not much else can be done with an adapter.
          • 34844
          if you look at the cover, it was obviously meant to be used with a few zip ties. the whole idea of it is you can easily work on and repair the harness. electrical tape is uneccesary.
            • 34844
            you could put the C101/adapter where the diagnostics port goes, and put the diagnostics port inside the cover. don't know if it will reach but it's an idea.
            • giantkeeper
              • Aug 2009
              • 1416
              True story
              Always Always go for the reach around if there is an option
              • Jand3rson
                • 37587
                That is THE WORST idea. It will be next to impossible to stretch the tape tight enough to hold the wiring as well as zip ties. Not to mention a total mess, if you ever want or need to take it off. All you need to remove zip ties are cable snips.
                • Dj Syco
                  • 382
                  granted thats how mine is right now and works perfectly and no trying to pry the cover back on each time. Why would you ever need to get back to your wiring harness anyways? yes it may be a bit "unnecessary" but cleans up the look a lot. just to double check I'm talking about wrapping the harness itself not the cover, which should be held on by the 3 screws made for it. I can snap a quick picture if you guys want. Nando also has a good idea about the adapter. pretty much what I was saying but will probably keep more of the wires out of the way.
                    • 34844
                    I don't see how it cleans up the look if it's covered by the plastic housing?
                    wrapping it will make it a pain in the ass to work on. I've actually got a few things I want to go in and modify..
                    • Dj Syco
                      • 382
                      alright, was just a suggestion. just throwing out another option was all.
                      • Jand3rson
                        • 37587
                        I had to get into my harness after it was already all bundled up in zip ties because we fried a wire and had to replace it. You never know what might happen or what you might have to change, so why not make it easy on yourself? I ALWAYS try to think of what will make it easier next time for me or for the next guy.
                        • 328ijunkie
                          • May 2007
                          • 3961
                          I just dont fry wires ;)
                          Check Us out on Facebook
                          Full Product Line Tuning
                            • 34844
                            he had an "adapter" from you know who. :p
                            • Jand3rson
                              • 37587
                              Yeah, but that wasn't "you know who's" fault, we did that shit. We never even use that adapter, Andrew took one look at it and ripped it apart.
                              • iwantspeed
                                • 3164
                                Got rid of some of the wiring.
                                Project
                                Parts for Sale
                                Feedback
                                YouTube Channel
