which valve cover gasket
  • Unearth078
    • May 2008
    • 2623
    i have a s52, with a m50 valve cover that aides in the obd1 conversion.
    so which valve cover gasket do i get.. m50 correct?
    never understood what the diffrence between the two of the gaskets were.
    Originally posted by Lof8
    4 doors allow you to transport more whores.
    therefore, their value is much greater.
    Down to: 89 aw2 332i/4/5 , 70 Sahara 2002
  • coreyw
    • Jul 2010
    • 368
    I would think that if the m50 valve cover bolts up to the s52 head, then the gaskets are the same.
    S52 Swap
    Shtuff For Sale
    • Unearth078
      • May 2008
      • 2623
      supposedly not. looks like the m50 one is the one to go with.
      More or less looking for one more yey to place my order.
      • samiam3356
        • Jul 2009
        • 1901
        I would think the valve cover that you have would be the gaskets you want.
        Originally posted by Roysneon
        $5 shipped?
        Originally posted by MarkD
        You are a strange dude, I'n not answering any more posts from you.
        • Unearth078
          • May 2008
          • 2623
          • ForcedFirebird
            • Feb 2007
            • 8300
            I have both motors in the shop, gimme a few a minutes...
            john@m20guru.com
            Links:
            • ForcedFirebird
              • Feb 2007
              • 8300
              Gasket needs to match head, both valve covers are flat on the bottoms.
              john@m20guru.com
              Links:
              • Unearth078
                • May 2008
                • 2623
                sweet, s52 it is then.
                • jrdeamicis
                  • Nov 2008
                  • 956
                  Gasket matches valve cover. I swear....
                  Past Car : E30 S50 6 Speed 5 Lug 3.73
                  Current : Z3 S50 OBD2 (Smog Legal) 6 Speed BBS RN Dual Ear Diff
                  ___________________________________________
                  BNB Designs
                  Engine Swaps, Fabrication, Innovation, General Repair
                  Richmond CA
                  Julian 848-248-8029
                    • 37833
                    It makes no difference, use either one.
                    Grover Beach, California
                    BimmerHeads.com
                    • frankie591
                      • Feb 2012
                      • 545
                      Any recommendations on victor reinz or an alternative? Heard both good and bad things about vr, so I'm not sure what to go with.
                      • 328ijunkie
                        • May 2007
                        • 3961
                        wtf. You HAVE to use the VC gasket that matches your VC.
                        Check Us out on Facebook
                        Full Product Line Tuning
