Do I need full OBD1 harness?
    S52 to OBD1, is a complete OBD1 wiring harness required? Or can the OBDII be used? Sorry if this has been asked before, I couldn't find a definitive answer anywhere.
    S52 Swap
    Shtuff For Sale
    Yup. Get a whole OBDI harness. No sense in splitting the OBDII harness open to reuse some wires. The ECU plug will also be different.
      Sweet, I got one on the way but just wanted to clear up some confusion. Thanks!
      S52 Swap
      Shtuff For Sale
        Why not just run OBD2?
        Check Us out on Facebook
        Full Product Line Tuning
          Because I've read it's more of a pain to make OBDII work than it is to convert to OBDI. Plus you get some power gains from the OBDI intake manifold.
          S52 Swap
          Shtuff For Sale
            Stay OBDII and just get the extras flashed out. If you have all the OBDII stuff dont waste your money on buying new things just to go back to OBDI.
            Do your research and you will understand why you want to stay OBDII and why it will be cheaper.
            My Build
              Run the OBD1 manifold with OBD2. I do it all the time. Running OBD1 on an OBD2 motor is dumb.
                Well it's too late now. And I think OBD2 has higher standards for passing smog and getting the car legal in CA. And I've heard that it's hard to keep it OBD2, especially if you don't have an entire e36 parts car.
                S52 Swap
                Shtuff For Sale
