Oil Light Reset
  • Robert
    • Dec 2010
    • 3770
    Oil Light Reset
    How do you guys normally reset your oil light?
    I tried an e30 tool , doesn't work.
  • IRON-E
    • 16548
    Which tool did you use?
    @IRON-E30 aka Edwin:D
    • Robert
      • Dec 2010
      • 3770
      one that worked on my e30 .
      • Robert
        • Dec 2010
        • 3770
        i think it's different for the m50 wireharness. don't want to fry anything.
        • rlddlr53
          • Oct 2009
          • 1450
          is your diagnostic port functioning?
          • 328ijunkie
            • May 2007
            • 3961
            Should be the same assuming your diag port is wired.
            Check Us out on Facebook
            Full Product Line Tuning
            • e30s50dan
              • Nov 2008
              • 2076
              Short out those two pins! Can't remember
              NASA
              BMWCCA member
              PCA member 25yrs
              1991 318IS slick top
              1997 M3 sedan
              2001 325CI DD
              “whoever turns the wheel the least, wins"
              • Robert
                • Dec 2010
                • 3770
                not sure, how do i know if it works lolz
                • DesertBMW
                  • Aug 2011
                  • 1023
                  I had this problem, the green lights would not clear grounding pin 7. Then I just changed odometer gears on my cluster and I inspected the board and two batteries. The batteries are good, but then I noticed the damage on the board because I used longer screws on the bottom center trim part, the longer screws went trough the cluster digging and damaging the board, this may be the common issue.
                    • 37828
                    If it's not working you have a wiring issue, it should work no differently than when you had the M20.
                    Classic BMW Specialists
                    Grover Beach, CA
                    www.BimmerHeads.com
                      • 34835
                      yeah, somebody didn't hook up the wiring properly.
                      • Robert
                        • Dec 2010
                        • 3770
                        typical, it's one of those wireharness adapter that were sold on here.
                        • ZM Blue Devil
                          • Dec 2006
                          • 13836
                          this
                          Levent
                          %20levent@gutenparts.com
                          Ladies:
                          • mammoth_e30
                            • Nov 2009
                            • 818
                            bam. tear it all apart and start over.
                              • 34835
                              rymes with megschmoe?
