VIDEO DIY: How to wire your 24V motor ultimate noob guide
    Basically I received my harness from 328ijunkie and had to wire it so I made a DIY of the geist of wiring your 24V motor. I tried to make it as absolute simple I can. Hopefully this helps some noobs and isn't a complete waste of time haha.
    PS: For first timers it works great if you print out your pin-out chart and check off which pin you've done.
    Also I am well aware that the chart colors were wrong, remember, follow everything by the pin number, NOT by color! It varies between E30 years.
    Originally posted by TSI
    OEM+
    This isn't of use to anyone?
    OEM+
      its def of use, thanks alot ! going to be doing this in the next week or so
        im sure people that are learning or just about to tackle the swap will def find this useful!
          Thanks gentlemen.
          OEM+
            this is very helpful most definitely. but i've been trying to find bloodshote30's thread and it won't come up on the search function, can u please post the link. thanks!
            89 E30 S52
            Transaction Feedback.
              never mind i found it. i think.
              89 E30 S52
                Holy hell you sound like a condescending douche! no offense!
                lucky I wasn't there with Chuck on my shoulder telling me to shove my fist down your throat and rip out your larynx.
                So what's wrong with Daves harness? my car runs fine.
                Originally posted by 325Projectz
                don't listen to the diagram... listen to mr. swiss.
                :nice:
                  hmm really? I've never actually been told that. It was probably the fact that it was my 4th try making the video (messed up 4 times before and I dont have any video editing program looool) so I was probably just frustrated.
                  Nothing is wrong with Daves harness. I bought my complete uncut harness from him that's all.
                  OEM+
                    Yeah i sold him an 'unmodified' harness and a C101 pigtail on the cheapz cause he wanted to tackle it himself. Looks like he did a good job!
                    What year is your car btw? Whatd you do with pin 20?
                    And i hate to bump this thread as it may hurt my business ;) lol
                    Check Us out on Facebook
                    Full Product Line Tuning
                      My car is a 91 318is. I haven't figured out what to do with pin 20 for ABS power, I will look around and see where to feed it to. What do you usually do?
                      And I can't stress this enough, if you feel uncomfortable in any way doing this, don't! Wiring is one of those things that will get your head scratching for HOURS on end if you mess something up.Get all your wiring needs from 328ijunkie at Markert Motor Works, he'll do a much better job at this than this video will ever portray ;)
                      OEM+
                        Thanks! ;)
                        pin 20 needs switched power. I usually steal it from pin 6 on the C101.
                          2 things:
                          1) It makes perfect sense to make an adapter because its not only easier to handle than to carry around the entire harness (i do mine during off time at work), but youre also able to fix errors easier by taking out the adapter if you must fix stuff on there..or replace the harness should it get fried/damaged for some reason and there will be no need to re-wire. You can also sell your uncut M20 harness and just get a pigtail at the junkyard etc etc. Just random thoughts
                          2) I am not sure its correct to say "a lot of charts are wrong". Every wiring situation is different, 318, 325e, 325i, E36/E34 etc. You cant just go off some random chart and hope for the best. Do lots of research and unless youre lucky and find the EXACT chart that matches your exact wiring swap by model AND year...you should create your own chart off wiring diagrams and/or verify various charts to create your own to make sure yours will match your exact swap. Just saying
                            Originally posted by Styleprojekt View Post
                            2 things:
                            Lots of charts are either wrong in content, or wrong in application. The big problem is that even if the chart is "right," the person making it often doesn't know the small model year differences. Also, there is often some subtle stuff that won't prevent the car from running ok, but is still wrong that creeps into charts.
                            I agree on the adapter, though. The other nice thing is that it makes it much easier to add things when you need them / want them.
                            2002 BMW M3 Alpinweiß/Black
                            1999 323i GTS2 Alpinweiß
                            1995 M3 Dakargelb/Black
                            - S50B32/S6S420G/3.91
                            1990 325is Brilliantrot/Tan
                            1989 M3 Alpinweiß/Black
                              2 things:
                              True about the adapter, never really thought about it like that, but many charts are definitely wrong despite the model differences. Ive tried about 4 wiring diagrams and they all had a minor descrepency that i later figured out but nothing that prevented the car from starting.
                              OEM+
