Maybe this is written somewhere but still unclear.. Im working on a M52 ODB1 and I have the blue temperature sensor in the first port in the head and planning on getting the brown e30 cluster temp sensor (removing throttle body cooling) My question is, does the harness have to modified in any way or will the two prong connector on the ODB1 harness still work since the brown top has 1 prong.
Cts question
Originally posted by mtlbloodshot View PostMaybe this is written somewhere but still unclear.. Im working on a M52 ODB1 and I have the blue temperature sensor in the first port in the head and planning on getting the brown e30 cluster temp sensor (removing throttle body cooling) My question is, does the harness have to modified in any way or will the two prong connector on the ODB1 harness still work since the brown top has 1 prong.Past Car : E30 S50 6 Speed 5 Lug 3.73
Current : Z3 S50 OBD2 (Smog Legal) 6 Speed BBS RN Dual Ear Diff
___________________________________________
BNB Designs
Engine Swaps, Fabrication, Innovation, General Repair
Richmond CA
Julian 848-248-8029
Originally posted by jrdeamicis View PostThe single prong wire is dealt with at the C101 connector.
Check Us out on Facebook
Full Product Line Tuning
Originally posted by 328ijunkie View Postwww.markertmotorworks.com/MMWProducts.html
;) Shameless plug
Originally posted by mtlbloodshot View PostThat adapter has been on my list from when the project started :)
Originally posted by 328ijunkie View PostWhy don't you run obd2?
I would still run it OBD2. So many advantages.
