Clutch slipping on fresh swap
  • FredK
    • 14763
    Well, since you machined the flywheel and got a new clutch kit, I'd wait until some clutch material transfers and "seasons" both friction surfaces before I start pulling everything apart.
    • andrewm
      • 456
      Pilot bearing?
      1987 Delphin 325e Sedan - Natalie
      1990 325i 24v
      1997 Chevrolet K1500 Crew Cab 4x4 - The Centurion
      • Thrizzle
        • Aug 2011
        • 194
        New s52 pilot bearing. The clutch is broken in yes, it's got 10k on it. It's the same clutch I was using before the swap, and it worked great then.
        I guess I'll drive it for a while and see if it starts grabbing better.
        Thanks for the help!
        • Thrizzle
          • Aug 2011
          • 194
          If I didn't clean off the wd40 of the flywheel well enough, will it eventually get burnt off? Or will it saturate the clutch disc and ruin it?
          • andrewm
            • 456
            It wont burn off easily. Oil will seep into the disc material and ruin it over time. Is a light film worth taking it all apart now? I dont know. Are you sure your clutch disk isnt backwards?
            1990 325i 24v
            • Thrizzle
              • Aug 2011
              • 194
              Yea clutch disc is installed the right way around.
              I'm getting a light chatter when clutch is fully engaged, thinking it's the tob rubbing the pressure plate, which would disengage the clutch a little bit. Thought I had a perfect bleed but I'll try again.
              • 619E30
                • 1753
                Were your hands clean when you installed the disk? Any grease on the disk could potentially help it slip.
                Originally posted by audiquattrot
                bimmers b4 b*tches....remember that.
                1990 Alpinweiss 325i - secret 500whp build
                2000 Audi S4 B5 Laser Red
                1990 Nissan 240sx - Drift Missile
                2006 CBR600RR
                • Thrizzle
                  • Aug 2011
                  • 194
                  I took care to put my fingers on the disc as little as possible. But disc contamination is about all I can come up with right now. I'm gonna drive it a little more see if I can wear it in some, if not I'll replace it.
