Just blew it at the track
  • mentaleeill
    • 850
    #31
    Originally posted by butters
    question related to the 2.93 ratio choice... I have the same diff in my car realizing it's not the best for quick acceleration, but I always had the thought that perhaps there might be a benefit in terms of how many gear changes you need. what gear did you cross the line in?
    a buddy back in the day was all into his evo 9, and I forget the details but basically he was saying that the 5-speed cars are better on the 1/4 mile because the 6-speed cars need to shift (into 4th perhaps) once more during the run.
    of course, the less shifts the better. better off finishing at the top of a gear, then having to shift and lose revs.
    in an e30 with smaller diameter tires, the 2.93 with a zf is damn close to a factory e36 m3 gear set.
    • SwiftE30
      • Jun 2010
      • 998
      #32
      didnt the e36 m3's come with a few different diff gearing ratio's. I know the 3.73 was a popular one, came in the 97's. didnt the 95's have a 3.23 or something.
      1989 E30 Zinnoberrot Vert 325i OBD1 S52 turbo;IP
      • Jean
        • 18228
        #33
        Reaction time does not affect 1/4 time.
        60ft time does, A LOT. Meaning, the better you hook up off the line the better your time will be.
        I only dragged my e30 once, it's not easy to get a good 60ft, I ran better times than you did with m30 swap..but many things affect 1/4 time.
        Practice practice practice...
        • matthugie
          • Mar 2004
          • 1810
          #34
          No, the 95 came with a 3.15, the 96+ manual came with a 3.23, and the auto had a 3.91. There were no 3.73's in e36 m3's. I had a 3.15 with a euro 6 speed and loved it, but for drag applications a 3.23 would be much better than the 2.93 being run now. I agree with everyone else though, something needs to happen tire wise. I would suggest getting the rear fenders rolled and wider rubber all around.
          88 325is - S52 powered
          Originally posted by King Arthur
          We'll not risk another frontal assault, that rabbit's dynamite!
          • nrubenstein
            • 3148
            #35
            Good grief, 2.5 60' time killed you.
            I still don't know how you people do so much tire spinning. My 195/60 winter tires hook up just fine with my S50.
            2002 BMW M3 Alpinweiß/Black
            1999 323i GTS2 Alpinweiß
            1995 M3 Dakargelb/Black
            - S50B32/S6S420G/3.91
            1990 325is Brilliantrot/Tan
            1989 M3 Alpinweiß/Black
            • 328ijunkie
              • May 2007
              • 3961
              #36
              Auto 95s had a 3.23 and auto 96+s had a 3.38.
              Check Us out on Facebook
              Full Product Line Tuning
              • rThor432
                • Feb 2007
                • 3907
                #37
                Edit: ^^Beat me to it.
                There wasn't a 3.91 in the auto M3's.. Just non-M autos. Maybe you are thinking of the 3.38 from the '97-98 auto?
                • justin_l_
                  • Jun 2007
                  • 1079
                  #38
                  Traction at the track always seems to be far worse than typical street conditions.
                  mentaleeill, good luck pulling mid 1.xx 60' times with an e30. It is not an easy task, one of the hardest car to get a decent 60' I have driven.
                  • SwiftE30
                    • Jun 2010
                    • 998
                    #39
                    oh sory, somehow i got the numbers mixed up my bad. My brother has a 97 with a vortec V2 supercharger on it with OEM diff and im trying to get him to go to the 3.15. HIs first and second gears are worthless.
                    • mentaleeill
                      • 850
                      #40
                      when my last e30 was na i did 1.6's with stretched 225's on 9" wheels out back. throttle and clutch control is a must. after going turbo with the same tire setup, i was in the 2.5 60' range, 12.2 at 136. tire to power ratio was a little off.
                      • matthugie
                        • Mar 2004
                        • 1810
                        #41
                        Yep, that's what I was thinking of.
