Went to the dyno, something's not right...
  • jeffmn8
    • Jul 2010
    • 217
    Originally posted by 328ijunkie
    Thus my comment. No tuner makes a chip for 17.5s
    My tune is for the stock injectors. Turner chip # 4131-3004. I'm pretty sure TRM also has tunes for stock injectors..
    Midwest Spec E30 #64
    https://www.facebook.com/thestickergarage
      • 34827
      hondestly, overall I'd say the entire tune is too rich, not too lean.
      what's happening at ~6100rpm looks like a rev limit of some sort to me. Something like that could happen if you were getting synch loss with the crank signal.
      you don't need bigger injectors, either. the highest fuel demand is at peak torque, and you're way too rich there already.
      something else is wrong.
        • 34827
        Originally posted by justin_l_
        Max duty on injectors? I can't see the log from work so I'm just throwing it out there. More air without more fuel will cause a lean condition.
        no, it doesn't work that way. it looks like they're shutting off. max duty would most likely be near peak torque, and it would be gradual, it wouldn't just shut off. all max duty means is you command the injectors to open more but fuel flow flatlines.
        • Beej '86 325es
          • 2639
          Originally posted by jeffmn8
          I'll double check this tomorrow. I just swapped a VDO cluster into the car the other week, that has a glitchy speedo, but that shouldn't make a difference right?
          I don't think a glitchy speedo should matter that shouldn't matter. But your connection should be at your engine harness, so unless it's that connection wasn't made, then your VSS should be working.
          -Brandon
          '86 325es S50
          '12 VW GTI Autobahn DSG
          '03 540i M-Sport (sold)
          '08 Jeep SRT-8 (sold)
          For sale:
          S50 TMS chip for Schricks
          • jeffmn8
            • Jul 2010
            • 217
            Agreed that new injectors aren't completely necessary but it wouldn't hurt.
            When it hit the wall on the plot, the car kept accelerating. I could have taken it to 7k (i did on the first run)
              • 34827
              yeah, it was still getting minimal amounts of fuel. a car will still run at 18:1, things just get hotter.
              12:1 and below though, is pig rich for an N/A motor.. I can't see any benefit to even larger injectors.
              • jeffmn8
                • Jul 2010
                • 217
                Just checked the harness. The VSS is going to pin 14.
                • Beej '86 325es
                  • 2639
                  I assume it's a 325i chassis? If so, I think that's incorrect. Verify that before changing it though.
                  -Brandon
                  '86 325es S50
                  For sale:
                  • jeffmn8
                    • Jul 2010
                    • 217
                    It's a 318is chassis and its going to the correct pin.
