It seems I have a couple of options:
1. Get a M20 singlemass flywheel, have it machined (remember, wont fit on a M50 without shaving), redo all the work I did to put the trans, buy a new starter fit for an M20. This would be all for a motor I'm going to use for like a month longer............so this is VERY unappealing to me
2. Get an M20 starter, Change the starter bendex pinion to an M50 pitch one (im running an M50 flywheel). I don't know how to change a bendex gear out or if it's possible
3. Space the trans out away from the motor, this is probably feasible with the dust shield and about 1 washer between the trans and block. Though I don't know how healthy this is for the pilot bearing/input shaft of the trans. This will locate my starter closer to the flywheel.
Option 2 I think would be the best though I don't know anything about doing it.
