Breaking axles
  • jrdeamicis
    • Nov 2008
    • 956
    If you are using an E36 driveshaft you have a ujoint behind the CSB. So it should be able to accommodate its new change.
    Past Car : E30 S50 6 Speed 5 Lug 3.73
    Current : Z3 S50 OBD2 (Smog Legal) 6 Speed BBS RN Dual Ear Diff
    ___________________________________________
    BNB Designs
    Engine Swaps, Fabrication, Innovation, General Repair
    Richmond CA
    Julian 848-248-8029
      • 34839
      There should be no change - you want the driveshaft alignment to be straight, and the diff in the same position.
      I have no idea why they suggest the offset bushing - it's not the "right" way to do it. Let's just say, your driveshaft rubs and your pinion is at an angle, mine doesn't rub and everything is straight..
      • Holland
        • Nov 2008
        • 7212
        This is pretty much why I went back to stock subframe height and went with adjustable camber and toe kit.
        Originally posted by DEV0 E30
        • IrocE30
          • Nov 2011
          • 104
          I am using a an e36 driveshaft, spaced the diff down 3mm and it just barely clears, still using the offset bushing. Thats how its gonna stay till i find that it causes other problems.
            • 34839
            It's really not a big deal.. You need about a half inch longer bolts and washers, that's it. I had a weld in kit, but the shorter bushings brought me back to specs, it wasn't worth the effort to me so i sold the weld in kit.
              • 34839
              Your pinion is still at an angle to the driveshaft, which can cause premature pinion bearing wear.
              • IrocE30
                • Nov 2011
                • 104
                I gonna look into i, since i did do a motor swap the driveshaft angles could all be screwed up depending on what motor mounts, tranny mounts i used. Im gonna use an angle finder and get the get them all level and space acoordingly.
                • nrubenstein
                  • 3148
                  Of course, what you lost is the improved roll center geometry that you can only get by shifting the subframe up.
                  2002 BMW M3 Alpinweiß/Black
                  1999 323i GTS2 Alpinweiß
                  1995 M3 Dakargelb/Black
                  - S50B32/S6S420G/3.91
                  1990 325is Brilliantrot/Tan
                  1989 M3 Alpinweiß/Black
                  • Holland
                    • Nov 2008
                    • 7212
                    I think 9mm to 12mm would hardly be noticeable, especially considering it's a small section compared to an entire car. I'm more concerned with driveline angles at that point.
                    • Adrian_Visser
                      • Jun 2006
                      • 2823
                      Who is running raised subframe bushings+weld on camber and toe adjusters?
                      I am about to install both, I have heard that it gets pretty tight between the adjusters and the body of the car when the subframe is raised. I hope I don't have to cut off any of the adjuster.
                      '89 Alpine S52 with goodies
                      • Holland
                        • Nov 2008
                        • 7212
                        Idk about eccentrics, but the IE posi-lock kit will touch with stock height.
                        • surebimmer
                          • Jan 2004
                          • 978
                          When i raised the subframe on my e30 m3 the driveshaft rubbed the gas tank as well. This is what i did.
                          I got (4) 40mm M12 x 1.5thread pitch bolts from McMaster.com. Then I found 1/2 inch bearing sleeves at my local ACE hardware store.
                          They work prefect to space the diff down, 1/2 a inch is 12.7mm.
                          I bought (4) 40mm M12 x 1.5 tread pitch bolts from McMaster.com
                          Then installed them and now my drive shaft will spin freely.
                          • Adrian_Visser
                            • Jun 2006
                            • 2823
                            That's what I bought should be interesting fitting them.
                            • Holland
                              • Nov 2008
                              • 7212
                              I'm at stock height and the camber adjusters are touching the floor pan.
