M50 exhaust , Y-pipe or dual/single muffler
  • bassakos
    • Sep 2011
    • 35
    my setup now is , stock M50 headrs custom Y pipe to single 2,5 custom muffler to 2,5 single back box
    the problem is that the first muffler is broken so i have to replace it
    i have found a magnaflow muffler 2"dual/ 2,5" single
    i am thinking to install that and get rid of the Y pipe
    need some feedback please
    does anyone uses the magnaflow?
    http://www.ebay.com/itm/Magnaflow-12...ce520b&vxp=mtr
    1989 325 M50B25
    1988 318 M40 R.I.P
  • Jand3rson
    • 37587
    I would advise against the Magnaflow Y, it's HUGE. The Flowmaster Y is a much better design, more compact and also cheaper:
    • bassakos
      • Sep 2011
      • 35
      sorry my mistake i mean magnaflow muffler
      1989 325 M50B25
      1988 318 M40 R.I.P
      • valleymotorwerks
        • Jul 2005
        • 174
        Dual will give better bottom end torque
        Valley Motorwerks
        1988 E30M3
        • Jand3rson
          • 37587
          True, but it's probably a pretty negligible amount.
          • bassakos
            • Sep 2011
            • 35
            so it will be better to go from setup A to setup B
            1989 325 M50B25
            1988 318 M40 R.I.P
            • 325e10
              • 161
              I stuck with true duals all the way back.
                • 34839
                no. absolutely not.
                once you merge the exhaust from the two headers (either with an X, like stock, or a Y, to a single pipe) there is zero difference. everything after the merge is meaningless for torque production - except for noise cancellation, and increasing restriction.
                • FredK
                  • 14761
                  Setup (a) will be better. How much better is largely dependent on the quality of the 2-into-1 collector.
                  Nando is correct. A dual exhaust has the potential to give you the most ground clearance. I would add that a transition after the merge can further enhance power, so most engineered collectors in non-sound-restricted racing series will have a long shallow angle megaphone with a reverse cone end.
                  The reverse cone isn't practical for street-driven cars due to packaging issues and extreme sound levels. So, a megaphone ought to transition into exhaust tubing sized for your application.
                  • bassakos
                    • Sep 2011
                    • 35
                    so i will keep my Y custom pipe and replace my broken 1st muffler
                    thanks for the info :)
                    1989 325 M50B25
                    1988 318 M40 R.I.P
