I'm up in Lynchburg Virginia right now, and noticed the first signs of heavy clutch slip this afternoon, on the way to lunch. In 2nd gear at WOT, it will not put the power down. I'm running an E30 M3 sport HD clutch with the it's HD pressure plate.
Should I get the Ireland 6-puck clutch, it's available in sprung or un-sprung. With that clutch, do you need a different pressure plate? It makes about 270hp adn 260 ft pounds.
stu
stu
