I have a 93 touring with a 94 E36 M50tub25. It cranks over but does not start. I have the relays grounded and the fuel pump and ignition power is connected properly.
The fuel pump does not prime with key 'on' and doesn't run with key turned to 'start'. There is power to the coil connectors with ignition on but they are not firing. I'm assuming there is constant power to one spade, a ground is another and the third one should be to fire the coil?
I'm also assuming that the DME fires the coils based on a signal it gets from the crank sensor.
I think my problem is due to a ground issue. The three relays are grounded. I have one going from the mount arm to the frame rail like it was stock, the one near the DME that plugs into the harness above it under the dash, I just need to know what else should be connected?
I'm quite sure I'm missing one on the valve cover, what else?
