My wiring thread- No fuel, no spark, here are my ideas
  • shiboujin
    • Feb 2006
    • 2791
    can you take pictures of your wiring job? Did you hook up the red power wires to the dist block and the brown ground straps to the shock tower?
    • Roysneon
      • 4505
      Yeah, I've got the ground straps bolted to the shock tower and the starter wire and fuse box cables are off the pos. terminal. I also just put the jump start wire on the batt terminal so it would be flopping around.
      I'll see if I can get someone to send me pics of the connections I made. The car is an hour drive away so I can only work on it on my days off when I can get a ride down there.
      Originally posted by mbonanni
      I am a pursit now.
      • surebimmer
        • Jan 2004
        • 978
        Do you have the ground from your motor mount arm to the body?
        • Roysneon
          • 4505
          Yep, have the factory on the exhaust side.
          I am a pursit now.
          • shiboujin
            • Feb 2006
            • 2791
            start wire on the batt terminal what now?
            Also, you might have blown your fusible link in the trunk.
            • Roysneon
              • 4505
              My battery is in the front. Thanks for the replies, guys. I just really miss my car.
              I am a pursit now.
              • e30shmobberr
                • 1934
                i had the same symptoms and this is how i fixed mine (just something to look for). When I cut my x20 off of the harness to splice the harness to the c101, it turns out i cut the connector off right before 2 ign green wires lead up to 1 then to the x20. so when i connected the one big green wire for the ign, it really need the small green wire too for the car to start.
Name:	Screen Shot 2012-05-20 at 7.13.01 PM.png
                check to see if you had done the same thing or not. maybe it'll be it
                Patrick - IG:niicknac
                RIP 1987 BMW 325is - S50'd ZF 6-speed, flared, bagged
                • Roysneon
                  • 4505
                  So you're saying that on the engine side there should be two wires hooked up to the ignition power wire coming from the car? That would make sense as to why the DME has no power if that's what the other smaller green wire goes to.
                  I am a pursit now.
                  • e30shmobberr
                    • 1934
                    thats exactly where it goes
                    • Northern
                      I like cupcakes & sh!tboxes
                      • 5237
                      shit, hadn't heard any updates on this since last thurs when my phone died.
                      Do you still have the engine ground wires and are they hooked up?
                      maybe check an m40 car's ETM and cross check the wires there.
                      Originally posted by priapism
                      Originally posted by shameson
                      • Roysneon
                        • 4505
                        Yes, all grounds that I know of are hooked up. Brown ground straps from the wiring harness are on the shock tower, engine is grounded off the motor mount arm to the frame rail.
                        I have not be able to find an M40 ETM, let alone one for a post 92 E30.
                        I am a pursit now.
                        • Northern
                          • 5237
                          sounds like its going to be a "trace the wires" game.
                          • GunMetalGrey
                            • Dec 2010
                            • 1499
                            Check the wire that branches off with the diagnostics plug, make sure that is grounded.
                            Thats what got me :)
                            • GunMetalGrey
                              • Dec 2010
                              • 1499
                              And there is the ecu power wire as mentioned before, and I am basing this off an e36 harness fyi
                              • SwiftE30
                                • Jun 2010
                                • 998
                                you might want to do this. I was literlly trying to figure out your same problem with my swap and i simply grounded the ECU with an extra wire and it fixed my problem.
                                i was under the impression the ECU was grounded through the harness so thats probably what gunmetal is talking about here. My wire branching off the diagnostics connector isnt hooked up so im going to try that and get rid of the extrs ground i added and let you know.
                                1989 E30 Zinnoberrot Vert 325i OBD1 S52 turbo;IP
