E34 V8 one works perfect..
					Use the Stock Booster - Modify the Clevis
Check Us out on Facebook
Full Product Line Tuning
OBD2 Tuning Available! OBD2 E36, S54 Swap, S62 Swap, etc: tuning@MarkertMotorWorks.com Dyno Thread -
I can weld you up one real quick :dunno :P
OBD2 Tuning Available! OBD2 E36, S54 Swap, S62 Swap, etc: tuning@MarkertMotorWorks.com Dyno ThreadComment
Anyone have an extra brake clevis they did not need? I will buy and pay shipping, PM me.View my build thread. http://www.r3vlimited.com/board/showthread.php?t=287724Comment
I did this to my car, now the brake pedal itself will not touch the brake light switch.... did I threat the clevis on too far??Comment
RealOEM has the answer
ATE: http://www.realoem.com/bmw/partxref.do?part=34331157416
Girling: http://www.realoem.com/bmw/partxref.do?part=343311579081990 332i, 4 door
2008 KTM 990 Superduke
2018 Golf R, 6spd manual (Pending delivery)
2017 Mazda CX-5 GT
2007 Z4M Coupe - Sold to very nice peopleComment
Perfecto!RealOEM has the answer
Girling: http://www.realoem.com/bmw/partxref.do?part=34331157908Comment
We can make modded clevises again.
I want to add with my experience with using the stock Booster.
If you have proper tools your job will be more exact and clean and faster.
I purchased 328ijunkie's modified clevis. Very nice.
I made a template with thin sheet of metal using pedal box where it mounts to the firewall/booster.
I measured corner to corner. not center to center. From side of hole to side of hole. not center of hole to center.
Made holes for the template and put it on firewall to verify. Made the holes and had to make the center hole bigger due to moved booster. Brakelines have to move moved/bent just a minimal amount just to have clearance for everything.
I then had to do the same to the pedal box assembly. Please note after reading you cannot add nuts to the top but i wanted to because the firewall is so thin and you can see it flex when pressing the brake pedal down. So i then had to cut piece of the bracket off on top and doing this does not change the integrity of the pedal assembly.
After test fit with the m50 manifold, i only had to shave off the 2-3 fins and made it appear oem. Doing this the first time was a struggle but if i had to do it again i would def do it the half amount of time. Longest part was cutting. Making the template is very important as it makes everything more exact. I made my own gasket for the booster to firewall that you can get from vatozone by the foot for extremely cheap.
Compared to spending more for a different booster i believe its worth it and i do believe i would do this again or opt for booster delete in the future.Comment
clevis mod worked like a charm..... learn from me and make sure of a few things
1. make sure your running the correct e28 green motor mounts.. or you still won't clear
2. shave the fins on your manifold after test fitting to make it look nicer.. I shaved mine at work and shaved way higher than I needed to... it won't cause any function problems, but woulda looked nicer!
