Passed the BAR exam!
  • blackhawkimpact
    • 2415
    Have pics of your exhaust setup?
    • K1CKBAC
      • 306
      Did he ask you for the VIN number of the donor car?
      My expectation is an immediate 5 speed swap. Autos suck more than a 50 year old whore.
      • reelizmpro
        • 9559
        To my knowledge, E30s are exempt from the evap test. I don't think a swap makes a difference either.
        88 M3 - LACHSSILBER
        89 M3 - ALPINEWEISS II
        • amcink
          • 788
          Subscribed for my Swap
          • P.Kelly
            • Aug 2011
            • 367
            Ernie, do you have a picture of your engine bay?
            The Definitive 1991 M-Technic Thread - a work in progress
            • Jean
              • 18228
              Having gone through this myself, it was pretty straight forward I want to add as well :)
              Now, you've gone through the OBD2 to OBD1 and then through BAR, is it safe to assume they did not/do not know it's a 98 or were they OK with the OBD1 swap?
              Not clear from your post, it seems like it could be taking either way...
              • AndrewBird
                The Mad Scientist
                • 11898
                At first I was like, "Why isn't this in off-topic? Must be spam." Then I was like, "Ah, makes sense."
                • R3Z3N
                  • Jan 2011
                  • 3056
                  +1 Curious. It sounds like the engine vin was not checked.
                  • eandrade
                    • Jan 2007
                    • 117
                    • BAR Referee did not ask for VIN of donor car. He did not look for the VIN sticker at the back of the cylinder head (it's pretty much inaccessible anyways) or the model number on the block.
                    • I explicitly told him it was a motor from a '95 M3.
                    • I'll post a photo of my engine bay in a subsequent post.
                    As for photos of the exhaust, these are the only photos I have:
                    Muffler by BrownGuacamole, on Flickr
                    Mid pipe by BrownGuacamole, on Flickr
                    X-pipe by BrownGuacamole, on Flickr
                    1990 325i
                    • eandrade
                      • Jan 2007
                      • 117
                      Actually, not true. During the BAR engine change certification, the referee pressurized the gas tank and squeezed the line on the EVAP can. Also, I remember the smog technician doing this when I had my car (with the old M20) smogged 4 years ago.
                      1990 325i
                      • eandrade
                        • Jan 2007
                        • 117
                        As requested...engine bay photos
                        The car is dirty as f*ck, but she goes like hell and is smog legal!
                        Overhead shot
                        Untitled by BrownGuacamole, on Flickr
                        ABS pump relocated to passenger side firewall
                        Relocated ABS by BrownGuacamole, on Flickr
                        Passenger side (you can see the OBD-II exhaust manifolds down there)
                        Stock US E36 M3 airbox w/3.0" MAF
                        Stock S50 Airbox by BrownGuacamole, on Flickr
                        1990 325i
                        • el bimmer
                          • 900
                          Glad I do not have to go thru this, but glad it passed! When I lived in Newark, NJ it was the same way. I had to go thru the same process, but no more for now.
                          • P.Kelly
                            • Aug 2011
                            • 367
                            E - Was it worth the cost/hassle of relocating the ABS so that you could run the stock air box? I ask because the K&N CARB legal unit is about $215 on Amazon. Mine is a cabrio, so my battery is in the engine bay. I could probably relocate it, but that's just one more thing to deal with.
                            • Jean
                              • 18228
                              OP - thanks for clarifying! I thought for a second you went through with OBD2 engine converted to OBD1 and they were OK with it LOL
                              • eandrade
                                • Jan 2007
                                • 117
                                Honestly, not financially worth it if the K&N option is truly a CARB legal unit. There were two reasons I went with the stock E36 M3 airbox:
                                1. I was struggling with a high-RPM CEL (MAF code) when I was running a 3.5" MAF + custom cone intake. The theory is that a stock airbox would smooth out the intake airflow and resolve this code. Unfortunately, both switching to the stock airbox & going back to a 3.0" MAF hasn't solved the problem. One of these days I'll get around to finally solving this problem.
                                2. Running a stock E36 airbox leaves me the option of running the Euro box if I decide to go 3.5" MAF -- but that's turning out to be a very pricey "upgrade"
                                Is the K&N a warm air setup? That would be my only concern with it. Although I'm guessing the intake honk/growl would be much nicer than with the stock airbox...
                                1990 325i
