Vanos &non-vanos intake cam
  • driftingminor913
    • Sep 2011
    • 358
    What if you put a non vanos exhaust cam in a vanos (m50b25TU) would it sound like its cammed at idle? Are the lifts different? Just asking cause I put it in mine when putting mine together and there isn't any big difference just wana know if it's wasn't a good idea.
    And it's in there in the first place due to a buddy snapping my regular exhaust cam
    Because V8
    http://www.r3vlimited.com/board/showthread.php?t=282219
    Doing it wrong since 91:wgaf:
  • DesertBMW
    • Aug 2011
    • 1040
    non vanos 1992 exhaust camshaft is the same as 1993-1995 vanos exhaust camshaft, same lift, same spec and timing tool will work
    • Robotin
      • Jun 2011
      • 4471
      Vanos is somerthing i still dont totally understand...
      but from what i do know..
      the vanos cams arent differnt. just the vanos shifts the cam to a more power efficient position.
      1989 325i SETA stroker [delphin] R3V'd 8/31/2011
      1989 325ix [zinnoberrot] $OLD
      1970 2002 [Nevada]
      Originally posted by Herr Faust Schinken
      guy must have slid into something that doesn't look like a car vs car hit
      Originally posted by ak-
      Must of slid into Rob
      • evandael
        • Oct 2009
        • 2881
        the vanos intake cams are vastly different. they aren't interchangeable with non-vanos intake cams.
        because m50's never had exhaust vanos, you won't have any issues on that front.
        the VANOS itself alters the cam advance/retard via a helical gear that is hydraulically actuated via oil pressure by a solenoid, either on/off or continuously (on m52tu's, m54's, and later motors). that helical gear meshes between the cam sprocket and the cam gear on the camshaft itself. those gears are the main difference between NV and vanos cams (lift/duration may also be different).
        • RobertK
          Kicked cancer's ASS.
          • Jun 2005
          • 5864
          What you're looking for is a Non-Vanos Intake cam. You can use it as an exhaust cam on a VANOS motor.
