I failed my BAR test
  • IRUNEDM
    • Oct 2009
    • 1122
    So this morning I went to Goldenwest College to take my BAR test. I have a S52 that's converted to a OBD1. I told them that the motor was from a 1995 M3 (S50). They asked me for paper work on the motor which I don't have since I purchased it from a private seller. They then started to do the visual inspection. About 45 min later, they told me that it didn't pass. They told me that I needed my motor ID'd by a licensed shop with the year and application. Also, it didn't pass because I plugged up the throttle body coolant hose so I could run a temperature sensor to the head in replacement of the throttle body coolant hose.
    I'm thinking about re-installing the throttle body coolant hoses and hiding the temperature sensor for temporary just so it passes the visual on that. As for getting the motor ID'd, I don't know how to go about that since it's a S52 that's been converted to OBD1. Any suggestions about what I can do to get my car to pass? I appreciate the help.
    Feedback
    Instagram - @e30_mtech2
  • giantkeeper
    • Aug 2009
    • 1416
    They are probably going to run the vin number from the block.
    Always Always go for the reach around if there is an option
    • scottinAZ
      • Dec 2009
      • 1312
      barring that, if the vin tag has been removed, they can identify by the pad on the drivers side under the starter (would be stamped 3.2 for the displacement). best option would be to truly do it correct, as in OBDII, or to sell the car out of state.
      you have been flagged by the Ref, and now things are in the system, dont see another way around it
      I saved 15% on my Bimmer parts by switching to ...
      • surebimmer
        • Jan 2004
        • 978
        Did they tell you how they would like proof that the motor is a s50?
        • IRUNEDM
          • Oct 2009
          • 1122
          They said I had to get a invoice with the vehicle #, year, make, and model.
          Feedback
          • quillbro
            • 369
            Easy solution, leave california, its a communist state.
            What about S50 valve cover? How are these rejects bmw experts... i dont get it.
            • Rsully70sev
              • 2391
              Create a fake invoice? Lawl, I have no idea, that's shitty. But yea, now big brother flagged you.
              • Robert
                • Dec 2010
                • 3770
                My ref told me that , once you go. It creates no red flag in the system.. I would recommend taking it to pierce college, they didn't even ask about any paper work... I just told them what car it was out of , and they took it from there... Pretty Simple.
                • IRUNEDM
                  • Oct 2009
                  • 1122
                  Sounds good. I will setup another appointment at the location you recommended. I appreciate your input.
                  Feedback
                  • Robert
                    • Dec 2010
                    • 3770
                    It's a little far, but worth it... Make sure your cats are smoking hot.... I drove 100 miles before my test in 4th gear LMAO...
                    • IRUNEDM
                      • Oct 2009
                      • 1122
                      I need to stop by Castro's too so I can knock out two birds with one stone haha.
                      Feedback
                      • thebutcher37
                        • 2877
                        Good luck man I hope Robert's solution works out ... sucks to hear.
                        Transaction Feedback
                        • IRUNEDM
                          • Oct 2009
                          • 1122
                          I just made another appointment for this Friday at Pierce College. Hope it passes this time.
                          Feedback
                          • R3Z3N
                            • Jan 2011
                            • 3056
                            +1 Hope you pass. S52 is quite enough fun....
                            • Robert
                              • Dec 2010
                              • 3770
                              how did it go
