What I have going on right now is a late 325 E30 rad with an IE pusher fan. The temp goes up above the half way mark, just around the 3/4 mark.
My questions are as follow.
I want to go back to a 318 rad (My car is a 318i) for a cleaner looking bay with the built in expansion tank. I'm using an E36 lower hose and a stock, uncut M42 upper. Do I need different hoses for the other rad? Is there a silicone hose set that will work with an M50tu and an M42 rad? Are there any aftermarket rads with a built in tank?
Any suggestions on how to make it run cooler? I know going to an M42 rad can't help much and will theoretically hurt it. I still have the stock thermostat and water pump, those are on the list, I'm running straight water until I'm confident that I have the cooling setup finalized. Besides what I just mentioned, what should I add to the list?
