and im running a stock rad and the fan from the ac condensor
Cooling system questions
sigpicFellow e30 enthusiast
Dont waste your time hating, aint nobody got time fo dat
1986 bronzit 325es- SOLD
1987 delphin 325i- parts car
1990 scwarz 325is- m50 drift slut
CHECK OUT THE BUILD!
http://www.r3vlimited.com/board/showthread.php?t=229234
Originally posted by golde30 View PostRun the e30 80deg tstat and drill a 1/8 hole at the 12oclock position. Bleed the system again, you shouldn't see the temp go past 1/2.
My M52 swap is running the following:
- E30 318i M42 radiator
- Dayco 71901 (This hose can be cut in the center and trimmed to provide both upper and lower radiator hoses)
- 80deg tstat (I drilled a 1/8 inch hole at 12' o'clock)
Bleeding method:
Filled coolant through upper radiator hose and overflow tank.
Jacked front end up 1 foot.
Opened bleed screw on radiator and let idle for 15 minutes (or ~ 1 beer).
No issues and coolant gauge never goes above 1/2 way.
When I first completed my swap I had the same issue but I was only using the stock aux fan. I upgraded to the mishi, 80deg tstat, and 16" spal pusher. Even in the extreme Phoenix heat, my needle never gets passed 1/2. Like everyone else said, with the lower tstat and proper bleeding you will be fine, many have done the same setup.
M50B25tu
I love CAR
Howdy
Welcome to this forum , here u can find lots of things , i suggest you have to contact your friends or any other expert for your question, right now i am not able to give u answer . sorry for that ........
Classified website
