M/S50 obd2?
  • 328ijunkie
    • May 2007
    • 3961
    #31
    Originally posted by S.Low
    ok i see what you guys are saying, makes sense...but non proper tune would not gradually get worse i figured...
    say i get a proper tune for this set up and works well and all..but then i plan to run this current engine turbo in the next year or so and was planning on having an rkTunes tune..would this override proper tune for this set up is what im worried about.
    If you plan to get a RK FI tune you should get his NA setup first. If he operates like we do, he should just charger a little more for a upgrade to FI
    Check Us out on Facebook
    Full Product Line Tuning
    • S.Low
      • Dec 2015
      • 26
      #32
      i had emailed him regarding the OBII set up but he has not yet replied. I'm hoping he would be able to do it.
      Since i'm in san francisco i like the fact that he can do it remotely. How are you guys set up to do that aswell by any chance?
      • 328ijunkie
        • May 2007
        • 3961
        #33
        Yes
        • S.Low
          • Dec 2015
          • 26
          #34
          would i need to send you my DME or will i be receiving everything necessary for you to do it remotely?
          • 328ijunkie
            • May 2007
            • 3961
            #35
            We send you a cable. All remote.
            • S.Low
              • Dec 2015
              • 26
              #36
              ok ill send you an email with details so i could get an estimate..will i still need to shave that front cover you think?and find a 60/2 wheel that vibrates the least? because i have like 3 spare motors laying around -_-
              • 328ijunkie
                • May 2007
                • 3961
                #37
                Try that before you get a tune. If you get one, dont bother.
                • S.Low
                  • Dec 2015
                  • 26
                  #38
                  well im going to get an NA tune regardless, just havent done due to low funds from holiday season.
                  hopefully soon ill get to it so i can have it in tip top shape, have a track event coming up and would like to participate.
