E36/ZF Shifter Carrier Length?
  • BBDirtbiking
    • Apr 2012
    • 323
    Please refer to the photo, item number 1.
    On the driver side of the carrier is a number saying C=###, does anyone know what that number is! Because I need it! It tells you how far it is from the center of the bitch clip to the center of the hole for the shifter.
    I am trying to find out what this length is on the E36/ZF so I know how much to shorten my E30 lever.
    So if you know what this number is, or have a way to find out easily, please help me out!
    Thanks,
    Brandon
    "Bayerische Motoren Werke - freude am fahren."
    Brandon {Current: 1991 318iS, 2007 328i, 2014 X5 xDrive35d | Past: 1992 525i, 1997 528i, 1999 540i}
  • BBDirtbiking
    • Apr 2012
    • 323
    Alright, I was able to get the number off the carrier using a mirror and some lights, haha...
    So here are my results!
    E30 318iS G240 shift carrier is 325mm.
    E36 M3 ZF shift carrier is 248.7mm.
    The difference is 3.004 inches.
    • 328ijunkie
      • May 2007
      • 3961
      wow. didnt know that haha.
      Check Us out on Facebook
      Full Product Line Tuning
      • BBDirtbiking
        • Apr 2012
        • 323
        Learn something new every day!
        • Farbin Kaiber
          Lil' Puppet
          • 29502
          Farbin knew this, even if he didn't know how or why this fact was in his mind, it was.
          • BBDirtbiking
            • Apr 2012
            • 323
            Lucky guess if you ask me, haha.
            • Farbin Kaiber
              Lil' Puppet
              • 29502
              Well, I was only off by .004, I'm pretty sure it was something I had read that was floating around in the back of my mind...
                • 34844
                can you use the E36 ZF carrier in the E30 with no mods?
                I have a "special" E34 carrier that I need to shorten.
                • Farbin Kaiber
                  Lil' Puppet
                  • 29502
                  Yeah, but it puts 1st-2nd to the right in the center of the shifter hole.
                  • BBDirtbiking
                    • Apr 2012
                    • 323
                    I was told that with the E36 ZF carrier and shifter it would put 5th right on the edge of the hole, almost not letting it engage. Upgrading to a short shifter or a Z4 shifter fixes this, and a lot shorter throw. :D
                    I am using my Momo short shifter, I will have my modified carrier and gear selector soon from the machine shop so I can feel it out. I will update me findings.
                      • 34844
                      anyone happen to know the length of the G260 carrier? I know the transmissions are different lengths.
                      • BBDirtbiking
                        • Apr 2012
                        • 323
                        It is stamped on the carrier as C=###.#, I don't have one so unfortunately I can't tell yeah what it be...
                        It was fun getting it off the E36 ZF as I was laying under my parents' M3 with a mirror and a flashlight, haha.
                        • Farbin Kaiber
                          Lil' Puppet
                          • 29502
                          Originally posted by BBDirtbiking
                          It was fun getting it off as I was laying under my parents' M3 with a mirror and a fleshlight, haha.
                          Delete three words, switch a vowel, and win is created...
                          • BBDirtbiking
                            • Apr 2012
                            • 323
                            Narcissistic using a mirror, haha.
                            • Farbin Kaiber
                              Lil' Puppet
                              • 29502
                              "What, I make myself hot?!" he says.
