Getting new tune, get 3.5" MAF while I'm at it?
  • khnordeen
    • Oct 2007
    • 459
    Currently running an s52 MAF on my s50 swap. I'm going to be purchasing a new tune from TRM since I will be picking up 21.5# injectors and will be getting a tune for my current setup (intake, LW FW, 21.5#, 91 oct.)
    Should I just pick up a 3.5" MAF while I'm at it and add it to the tune since adding it to the current tune I will be purchasing is no additional cost?
    -Kyle
  • Robert
    • Dec 2010
    • 3770
    yes, its an upgrade.
      • 34839
      no, it really isn't.
      • drumad
        • Aug 2009
        • 1700
        I'm too lazy to pull them up but if you go on bf.c, there are TONs of discussion concerning the 3.5" maf. Might want to read those and base your decision on that. After reading those personally, I'm convinced it's not much of an upgrade.
        2008 335i - n54b30
        1991 318i - m52b28
        1994 fzj80 - LAND CRUSHER
        • e30rapidic
          • 2167
          some say yes, some say no. Some do it just to add to the mod list in their sig.
          I found one at a junkyard for $25 so why not
          '87 325ic, powered by S50.
          • ACHTUNG
            • May 2005
            • 2397
            I have one if you decide you want one. I'll sell it to you for cheap dollars. $30 shipped.
            1989 US E30 Cammed S52
            Under Construction: 1983 Euro E28 Cammed LQ9/LS3 Heads/Jakeb E28 LSx Kit
            • MaksV
              • 1042
              I have some injectors for you if you need them.
              CHEAP REBUILT INJECTORS
              Need Quality Brakes? BimmerBrakes has it!
              For anything Else go with BluntTech!
              • RobertK
                Kicked cancer's ASS.
                • Jun 2005
                • 5864
                Doesn't hurt anything but not an upgrade that will give you noticeable gains unless you cam it out and install some 24# injectors.
                  • 34839
                  honest tuners will tell you, it makes no difference, but they still sell them because people want it anyway.
                  "mod list status yo"
                  • DesertBMW
                    • Aug 2011
                    • 1037
                    I tune both OBD1 and OBD2 ecus and I always tell people don't waste your money on 3.5" MAF and bigger injectors.
                    • CHITTY
                      • 79
                      Pm'd you about a possible trade.
                      http://importmotorsparts.com/
                      • johnjohnsons54
                        • Mar 2012
                        • 228
                        Would you say there's any danger in running a 3.5" MAF with a 3" tune?
                        The reason I ask is because the PO of my car threw in a 3.5" just before I purchased it. Mike at TRM mentioned some fuel trims (I think) would be a little off. The car runs great, but if it could run even stronger I'd certainly spring for a retune.
                        I do plan to put some shricks into the S52 next summer.
                        Anyhow, I'm just about to send the chip off to TRM for a 3.5" tune unless it would be a total waste of time...
                        ZF320 | M50 Mani | TRM + 21.5lb Injectors + 3.5in MAF | E36 M3 Rack/Driveshaft | Megan Coilovers | 002R/452's
                        In the works: UUC Evo 3/DSSR, JB Racing lightweight Flywheel, Shrick cams, BBK (yet to be determined)
                        I NEED A WINGLESS AW TRUNK LID PLEASE PM ME IF YOU HAVE ONE!
                        • johnjohnsons54
                          • Mar 2012
                          • 228
                          Bump for opinions on running a 3.5" maf with a 3" tune?
                          • eandrade
                            • Jan 2007
                            • 117
                            Don't run a 3" MAF with a 3.5" tune. It'll run pig rich.
                            1990 325i
