Noisy S50 tap / knock
  • RobertK
    Kicked cancer's ASS.
    • Jun 2005
    • 5864
    Ever since I rebuilt my S50 I have this phantom noise that sound like a mild knock when I start the engine cold but after 2~3 mins it becomes a very quiet tapping / slapping noise and it can only be heard between 900~1500 rpm. The engine runs great otherwise, very strong, with no hesitations or hiccups, no CEL. The noise has been the same since day 1 and never changes no matter how hard I run the engine or how long. Its been doing it for about a month now. (Will post a video later this evening)
    Engine has brand new lifters, new main tensioner, rod and main bearings, rings, and rebuild VANOS with new Besian seals and anti-rattle kit.
    I was told to try a new spring washer, intake sprocket and sec. tensioner but all those parts look to bein great shape.
    After reading this (http://www.r3vlimited.com/board/showthread.php?t=255807) I am beginning to think timing might be slightly off. We used the instructions from the BMW TIS to set timing but it never seemed to line up with the original oil stains on the sprockets.
    Before I crack open the valve cover again I was hoping some of you might have some other advice / opinions.
  • vandy
    • Nov 2011
    • 130
    Are you running A/C? I read something about a bolt from the A/C compressor bracket interfering with the motor innards...
    • RobertK
      • Jun 2005
      • 5864
      I have the A/C bracket and pump mounted but the A/C is not yet hooked up. First I've heard of that though. Shouldn't be any different that it being mount in an E36.
      • RobertC
        • Dec 2010
        • 127
        Taking a quick guess since the noise presented itself After you rebuilt the engine
        Stock Bores, Stock pistons, you honed the block to seat new piston rings, you now could have piston slap. Totally common and one of the reasons I will no longer build any engines reusing the stock pistons.
        Very well could be a sloppy chain setup if it was not done correctly. Either way, disassembly required. Hopefully its just a matter of resetting the timing chain.
        Good Luck
        www.facebook.com/E30motorwerks
        • RobertK
          • Jun 2005
          • 5864
          Videos I took today.
          Cold Motor ~ Just Started
          Warm Motor ~ After 15 mins of driving
          • RobertK
            • Jun 2005
            • 5864
            Good Luck
            I certainly hope not but with my luck so far with this engine, it wouldn't surprise me.
            • RobertC
              • Dec 2010
              • 127
              Ya that is not piston slap, that sounds like its in the chain assembly.
              You should be able to clearly hear where its coming from with a mechanics stethoscope.
              Either way it sounds like you got some problems in there. Best to crack that valve cover and recheck your timing chain for slack/slop, probably right between the 2 cam gears.
              I get an error when trying to view the 'warmed up' video.
              • RobertK
                • Jun 2005
                • 5864
                Fixed the warmed up video link.
                Weird that it resonates more in the top middle of the motor but you can hardly hear it from the top when its warm, just get a little bit of noise if you listen under the intake manifold or under the car.
                I'm really starting worry that it could be piston slap since people say it goes away when the car warms up.
                • e30shmobberr
                  • 1934
                  my s50 sounded like a diesel on cold start when the oil pump was starting to fail, but not yet failed. I had a fully refreshed head too.
                  possibly something like this problem?
                  Patrick - IG:niicknac
                  RIP 1987 BMW 325is - S50'd ZF 6-speed, flared, bagged
                  • RobertK
                    • Jun 2005
                    • 5864
                    Oil pump was replaced with a rebuilt one when I rebuilt the motor.
                    • RobertK
                      • Jun 2005
                      • 5864
                      Just tested, disconnecting the VANOS does nothing to change the sound.
                      • Robert
                        • Dec 2010
                        • 3770
                        Sounds like the timing is off, that's what it sounded like when we had the timing off on a 318, sounded like a knock , fixed the timing and the noise went away.. Double check the timing.
                        • reelizmpro
                          • 9553
                          On my m52 the spark plugs worked loose. Keep it simple.....hopefully its something easy.
                          88 M3 - LACHSSILBER
                          89 M3 - ALPINEWEISS II
                          • RobertK
                            • Jun 2005
                            • 5864
                            When your timing was off, was it off on the main tensioner or on the secondary sprockets?
                            • Robert
                              • Dec 2010
                              • 3770
                              It was off on the sprockets , we resealed the motor and the timing on the cams both intake and exhaust side were slightly off.
