Unfortunately, code 1222 seems to be a crap shoot of many possibilities.
Symptoms:
CEL
Runs kinda boggy (rich my guess)
car will die if you drive then let off the throttle while driving
I found a massive air leak at first, fixed it and went for another drive but the code stayed. Haven't had time to clear the code and try again though. I feel like it would go away if it was that simple. I can't find a good answer as to what the 1222 means. Could be O2 relay or could be maf leak.
Setup:
S52 (just installed vanos so maybe it's installed wrong?)
GTX3576R
Technica tune/blow through maf
silver 413 with pin 66 snipped
OBD1 stock E36 harness
Symptoms:
CEL
Setup:
GTX3576R
