Help yoshi finish his S52! *update* 1281 now
  • blackhawkimpact
    • 2415
    For example, pin 6 on the e30 side (02 sensor) is connected to e36 side pin 22 (reverse lights)??
    Can't really view the chart correctly since I'm at work and using my phone.
    • shiboujin
      • Feb 2006
      • 2791
      akg says it's unused http://www.akgmotorsport.com/e30convpins.html
      but from what I can tell, it's the power to the diagnostics port. Regardless, that shouldn't affect the CEL.
      also pin 6 is corroborated here: http://www.e30tech.com/forum/showthread.php?t=104761
      • blackhawkimpact
        • 2415
        AKG charts wiring are wrong. They always have been.
        Did you;
        Reset the codes. Disconnect the DME FOR 5 minutes. Reconnect DME and run it at idle for 3 minutes. Then drive for 30 minutes
        • shiboujin
          • Feb 2006
          • 2791
          AKG says to not even hook up pin 6 lol. I went around looking and I'm still pretty sure my wiring is right. I don't even think pin 6 is necessary.
          I'm gonna fix the power to the ECU (long story but it might the issue) then ground the chassis and try again.
          I kinda can't drive the car for 30 min as the reg/safety/emissions are all WAY expired.
          • blackhawkimpact
            • 2415
            Is your battery low? Low voltage can cause code 1281 to appear. You need to reset the code and drive it somehow like I said in the earlier post. If the code comes back, then it might be your DME that's faulty
            • shiboujin
              • Feb 2006
              • 2791
              so I read. I'm pretty sure the battery is good. I think the power feed to the ECU is parasiting with my two E fans. So I'm gonna give it its own power source and ground the case.
              • AnimalE30
                • Aug 2009
                • 266
                Originally posted by blackhawkimpact
                ECU doesnt need to be ground. At least not by mounting it. I had my ECU dangling inside the glovebox for weeks and car was running fine with no codes.
                That's weird, it fixed my stalling and wonky idle when I grounded it.
                • shiboujin
                  • Feb 2006
                  • 2791
                  grounded case and messed with power. yay that one is gone. Boo now I have a 1263 evap code >_<
                  • blackhawkimpact
                    • 2415
                    Take the evap purge valve off then put it back in
                    • shiboujin
                      • Feb 2006
                      • 2791
                      I don't have a purge valve though.
                      • blackhawkimpact
                        • 2415
                        Maybe that's why?
                        • shiboujin
                          • Feb 2006
                          • 2791
                          yea... but I don't want to run one. sooo what can I do?
                          • scottinAZ
                            • Dec 2009
                            • 1312
                            plug it in, but dont connect it. just looking for the part
                            I saved 15% on my Bimmer parts by switching to ...
                            • shiboujin
                              • Feb 2006
                              • 2791
                              yea I don't have one though lol. I want a $0 solution. Can't I just bridge it?
                              • RobertK
                                Kicked cancer's ASS.
                                • Jun 2005
                                • 5864
                                Plug in the purge valve from your M20, that will also make that code go away.
