i've got an s52 im putting into my 92 325i vert, its still obdII and I'm using the zf trans that came with it.
my questions are:
what slave cylinder SHOULD i use? i know you can use the regular g260 or the zf, each has there own problems from my understanding but which should i use?
what clutch line should i use? i have both M3 and e30 for a g260
will i have any problems not using the post cat o2 sensors?
i dont plan on using the secondary air pump, will that cause the engine to run limp? or will that just affect the cold start up?
and last, what do i use for a charcoal canister? or can i get away without using one? if thats the case how do i make that work out?
my questions are:
