Post Your M/S5X 24V Swap Setup
This is a sticky topic.
  • el bimmer
    • 900
    #61
    Very helpful!!! Great job guys!
    Neil, that list is very detailed! Thanks and I look forward to seeing the car.
    • Aviator
      • 616
      #62
      Originally posted by Neil1138
      Drivetrain
      Fully resealed ZF 320Z w/ full shift detent pin service, new OEM S52 Luk DMF, new Sachs OEM clutch kit, new E36 pilot bearing. New E36 M3 guibo, E36 M3 driveshaft w/ new E30 CSB into E30 S3.73 LSD.
      How's the ZF320 with the 3.73 work for ya? I have a 3.73 in my car now that I'm swapping an S52 with a ZF310 and I'm thinking the 3.73 will need to go for a 3.25 or 2.93.
      84 325e Burgundrot S52 M Tech 1.
      http://www.r3vlimited.com/board/showthread.php?t=250109
      • Neil1138
        • 527
        #63
        It's a ton of fun in the city but the gearing is too high for highway driving. Going to get a S2.93 in there eventually.
        • Bmwdayz
          • Apr 2011
          • 609
          #64
          I just finished my s52 swap yesterday and I'm running e36 trans with 3.25 diff. Tomorrow I'm picking up a 2.93 diff cause 3.25 is no fun on the freeway!
          • mikegar
            • Aug 2005
            • 523
            #65
            Engine- m50 block, 2.8l crank and rods, m50tu pistons, m50tu head and electrics, m50 intake manifold, m52 headers, m54b30 Intake cam, m52 exhaust cam
            Exhuast- shitty
            Tranny- g260
            Stock booster
            Red label 413 with generic chip
            F1 aluminum flywheel
            Spal pusher fan
            No ac
            No ps
            Originally posted by Ferdinand
            I carry a cheap pressure gauge in my glovebox with which to manually check my tire pressures, but I keep forgetting that in the USA glovebox space is sacred as it is reserved exclusively for the purpose of storing handguns.
            DIVING BOARD DIVISION DIVISION IDIOT
            • Hans Gruber
              • 157
              #66
              Engine
              S52B32 w/ 130k miles. OBD1 converted. Replaced the following prior to installation: all new OEM sensors, gaskets, grommets, and fasteners. Secured oil pump nut, all new hoses/vacuum fittings for crankcase ventilation/ICV and evap system. Running 21.5# pink top injectors (stock S52) and 3.5" MAF (540).
              Engine Wiring/Electrical
              E36 325i harness (manual). Removed X20 connector and re-pinned directly into replacement C101 connector. 413 Red Label DME w/ TMS chip.
              Drivetrain
              Fully resealed ZF 320Z w/ full shift detent pin service, new OEM S52 Luk DMF, new Sachs OEM clutch kit, new E36 pilot bearing. New E36 M3 guibo, E36 M3 driveshaft w/ new E30 CSB into E30 S3.73 LSD. Stock E30 g260 transmission crossmember w/ stock rubber mounts.
              Shift Lever and Linkage
              UUC EVO3 SSK (E36 M3) + DSSR (E36 M3), mounted in slightly modified E36 M3 shift carrier (to sit straight in opening).
              Motor Mounts
              E28 535i green mounts w/ passenger side spaced up 12mm. E36 mount arms
              Brake Booster
              E21 320i Brake booster w/ rethreaded/shortened stud, OEM E30 master cylinder, E30 fluid reservoir (all new gaskets/grommets)
              Steering System
              E30 325i steering rack, mix of E30/E36 supply and return hardlines, E36 fluid reservoir, cut/modified E30/E36 softlines.
              Cooling System
              OEM M20 radiator w/ M20 mechanical fan clutch and blades, stock M20 temperature sensors (blue and brown top), and stock m20 radiator sensor. Stock M20 top hose cut/modified to fit, random hose from autozone modified for bottom hose (both are straight w/ 90 deg bend at end).
              Exhaust System
              OEM S52 tubular headers w/ SAP delete plates > modified S50 downpipes > Y pipe w/ 3" output > 3" Vibrant race cat > 3" Vibrant UltraQuiet Resonator > 3" Vibrant StreetPower Muffler.
              After install:
              Currently:
              Also, my parts list. May find the P/N's useful.
              <3
              Your parts list= awesome. It really set me in the right direction. I JUST bought a s50 long block and needed this.
              My Pleasure:02 Honda 954, 02 Fronty 4x4
              My Pain:91 BMW E30, 90 S13(sr'd)
              "granthr said: ↑
              I mention Metric Mechanic because it is a great way to empty your wallet to get unverified horsepower gains."
              • dirtbag30
                • Apr 2013
                • 678
                #67
                +1 on that parts list. so very useful.
                i have no idea what i am doing with my life
                • Farbin Kaiber
                  Lil' Puppet
                  • 29502
                  #68
                  Is that list quoted or in the 24v Swap Thread? It should be.
                  • emmanuel.dlc
                    • Jun 2011
                    • 144
                    #69
                    Exhuast- shitty
                    Tranny- g260
                    Stock booster
                    Spal pusher fan
                    No ac
                    No ps
                    specs on the cams?
                    Sent from my LG-D801 using Tapatalk
                    • Neil1138
                      • 527
                      #70
                      Thank you guys! Now that I'm completely done with the swap, here is the latest version (a little bigger, may be easier to see):
                      Also, here is the (reset) Excel spreadsheet, if anyone would like to use it as a starting point: dropbox link
                      <3
                      • MyE30
                        • Sep 2013
                        • 326
                        #71
                        350 for the EVO3 + DSSR? Man I should have shopped around more. I paid 425 shipped when I bought mine.
                        • Neil1138
                          • 527
                          #72
                          I bought it around New Years, and UUC was doing a special. Buy the evo3 and get a free DSSR and free shipping.
                          • mikegar
                            • Aug 2005
                            • 523
                            #73
                            Originally posted by emmanuel.dlc
                            specs on the cams?
                            They are 240/228.
                            • Nick_S
                              • Apr 2011
                              • 3656
                              #74
                              Re-posting mine since I'm done and it's running now.
                              1. Engine
                              - 92 e36 M50NV. E34 pan and pick up All stock for now. A/C & PS delete.
                              2. Engine Wiring- E36 harness, adapter from Nando. 403 DME, Dinan Chip
                              3. Drivetrain-
                              G240, M42 dual mass flywheel, OE M42 Sachs clutch, G240 TOB and slave, 4.10LSD, E30 mounts. e36 325i driveshaft
                              4. Shift Lever and Linkage
                              - euro 320 shift arms, UUC shift lever, new bushings
                              5. Motor Mounts
                              - E28 green mounts, E36 mount arms
                              6. Brake Booster- stock, bone stock. Not even moved. Clearance is tight, about 1/4in but it doesn't hit it so why bother?
                              7. Steering System- E30 rack with condor PS delete plate.
                              8. Cooling System
                              - M42 radiator, new thermostat and 80C aux fan switch. Will be running a spal pusher eventually
                              9. Exhaust System- OBD-1 headers to E36 y-pipe. Had my existing exhaust trimmed and bent to meet the y-pipe. Super super simple. New bosch 02 sensor.
                              91 318is M50 swapped
                              05 Honda Pilot
                              24V swap thread
                              • moreoff
                                • Apr 2007
                                • 516
                                #75
                                Still building but this is how my setup is going to be. Have nearly all the parts, starting the swap this fall.
                                1. Engine- 95 s50b30us bored over .5mm w/ overbore JE 11.5:1 Pistons + Stage2 P&P Head w/ Titanium Springs/Retainers + 3.5" Euro MAF + ARP Hardware. Motor will be completely rebuilt brand new.
                                2. Engine Wiring- e36m3 harness rewired for C101 plug
                                3. Drivetrain- G260 + swap brace + AKG mounts + BlunTech E30 Spec Stage 2 Kevlar Clutch Kit + stock flywheel machined to 11.5lbs + 3.73LSD
                                4. Shift Lever and Linkage- UUC short shifter + UUC DSSR twisted 10 degrees
                                5. Motor Mounts- AKG Mounts + E36 mount arms
                                6. Brake Booster- Havn't Decided Yet but debating switching to a wilwood or tilton pedal setup but probably just slide my stock setup over a tad to start with
                                7. Steering System- E30 Rack + Power Steering Delete Plate from Condor
                                8. Cooling System- Mishimoto Aluminum Radiator + Summit Racing Pusher Fan
                                9. Exhaust System- Ebay Stainless Steel Header + resonator instead of Catalytic Converter + Supersprint SS Exhaust
                                My Build Thread
                                My Transaction Feedback
