Post Your M/S5X 24V Swap Setup
This is a sticky topic.
  • Jand3rson
    • 37587
    Originally posted by jrdeamicis
    The ernie mobile!
    Part of that M42 rad was for the stock airbox to fit. That engine bay is great.
    PLEASE refrain from quoting entire posts of the OP's list. We don't need the entire post replicated a dozen times throughout the thread.
    • ian e30 318is
      • Mar 2007
      • 1807
      Thread stickied, GREAT info!
      Awesome thanks Mr. Anderson :D
      1991 LS1 Swapped 318is
      Instagram:
      https://instagram.com/saltybeast/
      LS Build Thread:
      https://www.r3vlimited.com/board/for...s-e30-ls1-swap
      • lbreevesii
        • Aug 2009
        • 412
        1. Engine
        S50b30US with 95k out of a wrecked M3. Has schrick cams, 3.5" maf, 24# injectors, and a besian systems vanos seal and rattle kit.
        2. Engine Wiring
        Went with the S50's harness. Chopped the X20 off and crimped on new pins and popped it all into a C101. I also stripped out all the wires that don't need to run through the harness(AC bump wires, EWS wire, pulled the 02 sensor out of the harness so it runs like it did on the M42, etc). I had issues with the EWS on the silver label ecu and war chip combo . Switched to a red label + war chip.
        3. Drivetrain
        Using the zf that came with the engine. UUC ltw fly and OE M5 clutch. Used an E30 CSB o n an E36 328 driveshaft to an e28 3.25s diff
        4. Shift Lever and Linkage
        OE E36 M3 shift carrier. Z3 3.0 shifter, UUC DSSR(straight, not bent), delrin carrier bushings. The Z3 shifter had bushing material sticking out past the main metal part of the pivot that had to shaved off to fit the DSSR I got(unsure of exact model).
        5. Motor Mounts
        revshift blue(soft) 24v swap mounts. Pretty happy with them, but the stud lengths can be a pain on the bottom.
        6. Brake Booster, Master Cylinder, and External Reservoir
        944 booster, sotck MC and res for now. I'm not a fan of the remote setups... I used stock clevis and lengthened the threads. DO NOT try to do this with a harbor freight quality die. Its just frustrating. Go spend 6.00 on a quality die from fastenall. Took me two minutes with that die. I used a stock(including hose) E36 328 check valve with a new grommet from napa.
        7. Steering System
        E36 M3 rack, E30 lines. E36 ps res mounting bracket. I shorted the large hose coming from the pump to the res a bit. Routed the smaller one over the motor mount arm then back up into it. I'd love to have a shorter tube for it coming off the rack so i can run it under the motor mount arm.
        8. Cooling System
        I hate the look of the 325 coolant res. So until I can fab a better option, im' using an M42 rad(new) with a 16" spal pusher replacing the stock aux fan and retaining the OE dual speed setup. I cut up some random hoses from advance to make it all work.
        9. Exhaust System
        raceland shorty headers. Had the tube/flange area filled in and ground out so its smoother. Fitment/seal to the downpipes sucked, so new downpipes were fabbed. This goes into a custom H pipe with O2 bung, and 2.25" piping all the way back to a 2.5" dual in/out magnaflow. Note: I had to go with treehouse racing cabs to clear the tube flange. If I had to do it again i would try out the long tubes. However, the shorties clear my IE sway bar and subframe by a mile.
        not done yet, but heres how my setup looks.
        I don't always wreck cars, but when I do I wreck them into trees.
        91' 318is S50 swap - The Black Widow
        • 10Toes
          Me Father Was A Tree
          • Jan 2008
          • 61222
          1. Engine
          M52b28, OBD-1 swapped still useing plastic valve cover and OBDII coils,Pink 21.5 lb injectors, s52 cams, K&N hot air intake, TRM tune. Replaced waterpump, thermostat, sensors, seals and bolts prior to dropping in the engine, E34 525 M50 throttle cable, welded oil pump nut, race skids 24V plate, E30 M3 wire covers.
          2. Engine Wiring
          e36 325is harness, spliced on an e30 engine side c101 to connect up to the chassis side wiring.
          3. Drivetrain
          E46 ZF 320 , OEM E46 clutch and pressure plate, e46 pilot bearing. Used E36 328 4 bolt drive shaft and 3.25 lsd. Stock trans brace solid poly UUC red trans mounts (going to go with something softer and not thru bolt)
          Z3 3.0 short shifter and all new bushings, E46 carrier and selector both cut and welded.
          5. Motor Mounts
          E36 arms, Revshift Red mounts
          E21 320i booster, cut and rethreaded shaft to stock length, stock master.
          7. Steering System
          m52 return line, -AN high pressure feed line. e36 reservoir mount. Did an e36 95 M3 rack, had to grind a little bit off the fire wall (air bag car)
          8. Cooling System
          Mishimoto Z3 MS54 radiator, late model e30 expansion tank, 16" summit racing pusher fan wired into stock aux fan wiring. E36 325 upper hose with M42 lower hose trimmed to fit
          9. Exhaust System
          Ebay Superspring rep longtube headers (clear stock lolipops and big swaybar). Custom 2.5" system with megnaflow cat and megnaflow muffler.
          Older Pic
          • E30FreaK89
            • Apr 2006
            • 437
            Originally posted by eandrade
            1. Engine
            S52B32: full conversion over to OBDI (includes S50 valve cover, coils, fuel rail, manifold). I was lucky and the head had a 3rd pre-drilled hole for the coolant temp sensor.
            Shrick street cams (intake/exhaust)
            24lb injectors
            3" stock MAF
            Stock E36 M3 airbox
            Have you put your car on a dyno to see what your putting down?
            • eandrade
              • Jan 2007
              • 117
              Dyno sheet here: http://www.r3vlimited.com/board/show...19&postcount=2
              1990 325i
              • dougsic
                • Jun 2006
                • 284
                1. Engine
                s50 - Shricks, injectors, 3.5 MAF TMS tune. Dr. Vanos kit, retained A/C (10/92 'vert so already R34).
                2. Drivetrain
                stock 260, stock driveshaft, 3.73 LS diff.
                3. Shift Lever
                stock trans bracket modified to properly accept beefy e21 mounts. Cut hollow shift lever, inserted appropriate sized decapitated bolt and screwed other half of lever onto bolt - allowed me easy adjustment to get the rotation just right then welded both halves into place. Replaced all shift linkage bushings and 40k miles later - still tight.
                4. Motor Mounts
                e28 M5 with one .09" washer on pass side for header clearence.
                5. Brake Booster
                purchased new e21 booster (wish I'd painted it), shaved a few intake fins
                6. Cooling
                stock rad, stock clutch fan but had to shave blades a little (interferred w/Vanos slightly).
                7. Exhaust
                ebay Supersprint knockoffs, cheapo cat, custom single exhaust with resonator that's still too loud.
                • GunMetalGrey
                  • Dec 2010
                  • 1499
                  1. Engine
                  M50B25TU, E34 Throttle body, E36 Wiring harness with adaptor, m42 cover plate.
                  2. Drivetrain
                  G260 with lightened m20 flywheel and stock clutch, stock trans mounts (for now). Stock e30 five speed driveshaft
                  3. Shift Lever
                  Custom trans brace (My own of course!) to compensate for the 10 degree rotation
                  4. Motor Mounts
                  e28 m5 with custom made shim to clear exhaust
                  5. Brake Booster
                  E30 IX booster and master with DSM remote res(spliced in line for clutch res)
                  6. Cooling
                  E30 325 rad and overflow tank, 16" SPAL pusher
                  7. Exhaust
                  Knockoff SS headers (ebay) to a Y pipe going to a 2.5" tube, to an 18" vibrant resonator to a Magnaflow 12158
                  Car was five speed swapped at the same time.
                  • screwbiedoo15
                    • Aug 2009
                    • 79
                    1. Engine
                    Non-VANOS M50B25 from '92 525i.
                    Replaced all seals and gaskets prior to install, SKF Speedi-Sleeve on crankshaft rear main seal.
                    Kamotors intake w/ E34 intake boot.
                    How do you like the kamotors intake? I'm thinking of replacing my unprotected K&N filter with one. I assume when you say E34 intake boot you are using an E34 525i intake boot? I saw a picture of your set up in another thread and it looks really clean so I may replicate it.
                    • James Crivellone
                      Head Janitor
                      • 6301
                      In the racecar
                      1. Engine
                      M50B25 Non Vanos, E34 Harness, 405 DME,
                      2. Drivetrain
                      Getrag 260, stock single mass flywheel, 6 puck sprung race clutch
                      3. Shift Lever
                      Modified stock 260 trans brace, bent stock shift selector rod, AKG Sportshift shift lever
                      4. Motor Mounts
                      AKG Urethane Swap/Race Mounts
                      5. Brake Booster
                      E21 Brake Booster
                      6. Cooling
                      Late model 325i radiator / expansion tank. 16inch pusher electric fan
                      7. Exhaust
                      OBD2 Headers, E36 downpipes, custom Y pipe into a single, Magnaflow muffler
                      • openthrottle
                        • Jul 2012
                        • 4
                        ^how much hp did the redbull can give?
                        :p
                        good info and good idea for a thread....will help tons with people doing the swaps
                        • ForcedFirebird
                          • Feb 2007
                          • 8300
                          Just wrapped up this swap, thought I would share some pics.
                          Still needs an m3 battery tray cover and a few of the beauty cover screw caps, and exhaust, but it's in an d running strong.
                          Cover off
                          Going in
                          john@m20guru.com
                          Links:
                          • e30shmobberr
                            • 1934
                            Engine:
                            s50b30US
                            arp head studs
                            .080 mls head gasket
                            new vanos
                            freshened up head
                            cleaned pistons
                            new oil pump
                            some new gaskets
                            cone air filter
                            Drivetrain:
                            e36 m3 zf
                            new guibo
                            e30 325e drive shaft w/ new csb
                            3.25LSD
                            shift linkage:
                            stock e36 m3
                            wiring:
                            s50 harness, spliced on c101
                            exhaust:
                            s52 obd2 headers (welded up)
                            stock e36 m3 obd1 midpipe/cats
                            uuc corsa rsc36 cat back
                            motor mounts:
                            e28 m5 cylinder style
                            brake booster:
                            e21 320i
                            cooling:
                            e36 m3 radiator
                            oem ac fan wired to 82 deg fan switch
                            new late model expantion tank
                            waiting to go on:
                            tune
                            bigger injectors
                            3.5 maf
                            Patrick - IG:niicknac
                            RIP 1987 BMW 325is - S50'd ZF 6-speed, flared, bagged
                            • EürOV3R
                              • Jul 2012
                              • 126
                              1. Engine
                              M50TUB25, S50 cams, KA Motors CF intake, TMS tune. E30 318is throttle cable, safety wired oil pump nut, Speed-Freak's skid plate, Renewed Finishes powder coated valve cover.
                              2. Engine Wiring
                              It's an E36 harness, but I'm not sure about it exactly because I had to ground pin 66 before it would spark/fuel/fire relays. Apparently it was looking for EWS or something (on 2 different red label 413 DMEs). Mated to the E30 C101 by yours truly.
                              3. Drivetrain
                              E30 M42 Getrag 240, Euro 323i/early 528e single-mass (M20) flywheel @ 13.5lbs, M20 clutch/PP, Euro 323i TOB. E36 325 driveshaft, E30 CSB mounted in stock orientation. Z4 2.5i 3.64 torsen diff.
                              UUC E36 M3 Evo 3 SSK (p/n USCE), Euro E30 320i carrier, 320i/M3 selector rod
                              5. Motor Mounts
                              E36 arms, Revshift M42 blue poly mounts (round E28 M5 mounts in reserve)
                              E30 iX booster, 25mm Gerling master cylinder, 2002 reservoir
                              7. Steering System
                              Z3 2.7:1 rack, E36 reservoir location/lines, E30 pressure line
                              8. Cooling System
                              stock M42 radiator, FF Dynamics 16" fan pushing from in front of the A/C condensor. wired up to aux fan switch with lower temp switch.
                              9. Exhaust System
                              Raceland shorty headers mated to 318is y-pipe/cat/center section, fox exhaust E30 318is specific cat back (all 2.25")
                              • Mr.SWISS
                                • Nov 2005
                                • 1251
                                1. Engine
                                S52, OBD1 head ( rebuilt) IWS racing timing chains, Dinan stage 2 tune, Technica EWS and error delete. re pinned x20 to c101. Used OBD2 engine harness from an M52 car. ARP's and Cometic .70 MLS, fuel rail from 97 528i.
                                2. Drivetrain
                                ZF320 that came from 00 M coupe stock clutch, ZF slave, UUC line.
                                3. Shift Lever
                                Turner drop in ( old school )shifter and DSSR.
                                4. Motor Mounts
                                E28 motor mounts from 328ijunkie
                                5. Brake Booster
                                booster and master from e32 ( dual chamber same pn# as ix)
                                6. Cooling
                                Sock cooling system,e36 6 cyl upper and lower hoses.
                                7. Exhaust
                                Running ebay headers and E36 M3 cats and custom piping, still OBD2 all the way
                                Originally posted by 325Projectz
                                don't listen to the diagram... listen to mr. swiss.
                                :nice:
