Post Your M/S5X 24V Swap Setup
This is a sticky topic.
1. Engine
S52B32 with ODB2
Stock S52 internals
Stock ODB2 Fuel Rail, ODB2 FPR/Running Losses, Stock charcoal canister
KAMotors CAI
m50 oil pan, intake, dip tube.
S52 stock CCV and it's related rat's nest of vac lines.
Rebuilt S52 injectors by MMMPEG
2. Engine Wiring
ODB2 Harness, 100% verified, cleaned and tested to all 88 Pins on the DME. (First swap taught me valuable lessons, you get to delete everything you don't need and make sure everything works from the getko)
Wired directly as a C101 male end connection instead of using a X20<>C101 adapter
SAP/EWS/ASC and ABS (e30 body runs ABS) deleted.
E36 318i Firewall covers
Battery relocation to trunk
3. DME
Kassel MS41.1
4. Drivetrain
ZF 320
E30 early model E driveshaft with large guibo
Lightweight Flywheel/Clutch
E23 735i 3.64 LSD 188-Medium Case (Franken Diff- Removed original 4.10 open, swapped LSD carrier from e36 m3 3.15 and used original 4.10 open halfshafts on the e23 differential)
Garagistic 85a Poly Subframe, TAB, Diff and offset-CA bushings
Red Sump Armor Skid Plate
5. Suspension
Koni Yellow Adjustables and Racing Dynamics vert springs
Garagistic X-Brace (LOVE IT)
6. Shift Lever and Linkage
Converted from Auto
E30 Manual Pedal Assembly, Clutch master and slave
E36 M3 Shift linkage with Garagistic delrin bushings
Z3m Short Shifter
E30 Rubber Tans mounts on stock cross member (Had poly mounts and removed them, I had to go to the dentist after installing them originally....teeth grinding)
7. Motor Mounts
Condor Poly S5x Motor Mounts
8. Brake Booster, Master Cylinder, and External Reservoir
Massive Boosterless setup with e32 745i MC (Mixed emotions, but getting used to it)
Brembo Rotors
ATE Pads
SS Lines
9. Steering System
E36 M3 Rack with a mix of e30/e36 lines.
Cut and slotted firewall to accommodate the air bag e30 steering column....(no one tells you this, but the steering column needs to be moved down and to the right to clear the e36 rack)
10. Cooling System
Z3m Radiator and Late model coolant tank
E36 M3 S52 Hoses
80c thermostat
16'' SPAL Pusher with 80c temp switch and override switch inside. Wired completely standalone from engine and body.
11. Exhaust System
Aftermarket Headers
Vibrant Y pipe dual 2'' in/2.5'' out
Borla Mid Section
Magnaflow Performance Muffler
2.5'' SS from the headers to the tips, no cat and two upstream O2's off the header.
Old pics- but the thing runs like a Raped Ape!
555Garage - Kingston, PA
'13 BMW e70 X5 35d
'95 BMW e34 525i
'92 BMW e30 325i S52 Vert (Quade the Vert)
'92 Range Rover Classic
'90 Range Rover Classic
'89 BMW e30 325i Coupe (The DIRTY30)
'81 VW MK1 Rabbit Caddy Diesel
'76 Honda CB550K Cafe/Brat
'67 Pontiac LeMans
'24 Model T Depot Hack
....And a bunch of Motobecane, Puch, Garelli, Batavus and Honda 49cc-78cc Mopeds...
1. Engine
S52B32: fully functional stock obd2.
Stock s52 cams (intake/exhaust)
E39 528i fuel rail with built in FPR and vanity cover
stock MAF
KA motors air intake
e34 oil pan with stock baffle
Red locktite'd and safety wired oil pump nut
2. Engine Wiring
RobertK @ Kadunza
3. DME
Dave Markert @ Markert Motorworks reflashed my DME.
Removed:
-SAP
-EWS
-muffler valve
-bumped the redline
4. Drivetrain
ZF320 detent work done
stock S52 M3 flywheel / clutch
E36 M3 clutch slave cylinder
E30 325i clutch master cylinder
E30 UUC Stainless Steel Clutch hose
stock trans brace
E21 Trans Mounts with aluminum cups
Manual 325e big guibo driveshaft new CSB and Guibo
2.93 LSD (325etime capsule e30)
5. Shift Lever and Linkage
UUC Evo3 shifter
Stock e36 dssr
Garagistic Delrin bushings, front & Rear
ZHP Shift knob
6. Motor Mounts
AKG Motor mounts (expensive but great fit and beefy as hell)
7. Brake Booster, Master Cylinder
Porsche 944 booster (fits perfect, brake feel is firm and great)
Stock 325i Master Cylinder and resevoir
8. Steering System
Stock e36 328i steering rack (Rack Dr. rebuilt)
New E30 power steering line and custom made line
E36 power steering pump and reservoir
9. Cooling System
M20 late model radiator
Random Hose from Autozone cut to fit
80C thermostat
Euro Diesel fan mounted to stock e36 fan clutch
10. Exhaust System
Stock OBDII exhaust manifolds
custom downpipes made to mate OBDII headers to stock e30 exhaust
E30 midpipes and cats
Scorpion E30 muffler
(I know its a bit restrictive keeping the stock e30 components but it sounds amazing, not too loud but very deep with a nice over run sound and it's a vert so it's not like I am tracking it.)Last edited by Mwishlist; 04-07-2017, 04:26 PM.Thank god, R3V was getting boring since the ginger kid wrecked his car. - StoneaComment
1. Engine
M50b25tu from auto e34 90k
Stock M50b25tu internals
Upgraded VAC oil pump nut
Cometic MLS head gasket
ARP head studs
Rebuilt vanos unit
2. Wiring Harness
Kassel plug and play harness
3. DME
Kassel tune
4. Drivetrain
E30 early model E driveshaft new guibo
Resurfaced flywheel/clutch
2.93 lsd
Getrag 260
Garagistic trans brace
5. Suspension
Eibach springs
Lemforder control arms
Z3 Short shifter and bushings
7. Motor Mounts
1 green e28 m5 mount and 1 e28 mount
E36 mount arms
Ix booster master and late model reservoir
9. Steering System
E36 Rack
10. Cooling System
E36 radiator
16'' SPAL Puller
11. Exhaust System
eBay SS longtube headers fabricated into e30 midpipe
Dtm muffler. (Still needs to be fabricated until I find a better solution)Comment
Car: '88 WBS Vin'd E30 M3
1. Engine
2005 S54B32: fully functional stock obd2.
Stock S54 cams
Walbro 255 external and stock internal in-tank with Aero adj. FPR
Dinan High Flow Throttle Boddies
VAC U/D pulley for Crank
A/C delete
Intake: Bimmerworld silicone boot
Stock E46 M3 S54 MAF sensor
ECIS Replacement filter
E34 oil pan with VAC oil pump and pan baffle
Sump Armor-Red46
2. Engine Wiring
Wired by hand (no aftermarket harness used) Chassis harness to E46 motor harness
3. DME
Bimmerworld/Randy Mueller @ EPIC benchflashed my DME. Standalone MSS54 ECU setup
Removed:
-SAP
-EWS
-muffler valve
- redline set at 7800rpm
- Yielded 340rwhp/277tq on a dyno jet
4. Drivetrain
ZF320- 5spd from E36 M3 detent work done
SPEC clutch and lightened flywheel
E30 M3 clutch slave cylinder
E30 M3 clutch master cylinder
325i trans brace
E21 Trans Mounts
E30 M3 driveshaft new CSB and Guibo
2.93 LSD
OEM SSK Z3 M shifter
Stock e36 dssr
E36 Ebay 5 spd M Shift knob
6. Motor Mounts
Green Motor mounts-E28/E34? (Cheap and inexpensive but great fit)
2002 Booster (fits perfect, brake feel is firm and great)
Stock M3 Master Cylinder and resevoir
Brembo Gran Turismo Lotus 4 piston front BBK
8. Steering System
Stock steering rack
New E46 M3 power steering pump
9. Cooling System
New E46 M3 radiator
E46 M3 O.E hoses
Lower temp thermostat- Bimmerworld
New O.E W/P
SPAL 16" -Electric Fan with Relay kit 30102047 (straight blade-pusher).
10. Exhaust System
Stock OBDII S54 exhaust manifolds with chopped cats and custom 2.5 inch double piping. Custom merge-Y to mate OBDII headers to 2.5 magnalfow piping. 2.5 inch resonator and 2.5 inch muffler with double walled tips.
All exhaust pieces were manufactured by Magnaflow and purchased from Summitt Racing.
(With the merge being so close to the headers, I know its a bit restrictive down low in the rev band buy the car makes 320+ on any dyno so Im not complaining. I wish my E46 M3 sounded as good as this car. It is deep, European exotic and sounds amazing, not too loud but very deep with a nice scream up top to let the P-Car's know that I'm coming.If looks could kill:::Comment
1. Engine
Stock S54 cams
A/C delete
Sump Armor-Red46
2. Engine Wiring
3. DME
Removed:
-SAP
-EWS
-muffler valve
4. Drivetrain
325i trans brace
E21 Trans Mounts
2.93 LSD
Stock e36 dssr
6. Motor Mounts
8. Steering System
Stock steering rack
9. Cooling System
New E46 M3 radiator
E46 M3 O.E hoses
New O.E W/P
10. Exhaust System
340 wheel hp from a stock s54 and 2.93? Lol nahhhh
You sure that's not crank hp it's calculating?
Got any pics?
1. Engine
Stock S54 cams
A/C delete
Sump Armor-Red46
2. Engine Wiring
3. DME
Removed:
-SAP
-EWS
-muffler valve
4. Drivetrain
325i trans brace
E21 Trans Mounts
2.93 LSD
Stock e36 dssr
6. Motor Mounts
8. Steering System
Stock steering rack
9. Cooling System
New E46 M3 radiator
E46 M3 O.E hoses
New O.E W/P
10. Exhaust System
Got any pics?
1. Engine
M52b28 block, S52 crank, Molnar 135mm rods, custom JE pistons, 8.5:1 CR, OBD2, S52 cams, full Supertech valvetrain, CES cut ring head gasket, OBD1 valve cover and coils, ATI Super Damper. Everything inside the motor is brand new. Every seal, every bolt. Good N Tight T3 manifold, Garrett GTX3582 turbo, Mishimoto 31”x12”x3” intercooler, M50 manifold, Rally Road fuel rail, Siemens DEKA 60lb injectors, tuned on stock Ms41.1 ECU by 22RPD. Arc Asylum modified and reinforced E36 oil pan with VAC baffle and E30 front subframe.
2. Engine Wiring
E36 OBD2 harness converted by Markert Motorworks for plug and play with the E30’s C101, E30 M3 firewall wiring harness cover.
3. Drivetrain
E46 M3 6-speed transmission (420G), Southbend Stage 3 Endurance clutch, OEM S54 flywheel, DSS custom driveshaft, E28 Euro M353i 210mm rear diff with E46 M3 cover, 3.25 LSD, custom rear crossmember fabricated. E30 reinforced subframe with Garagistic camber/toe adjusters, Z3M rear trailing arms and axles. Arc Asylum 420G trans mount and Rogue Engineering trans mounts.
4. Shift Lever and Linkage
UUC Evo3 Euro E36 M3 shift kit, new E30 shifter carrier bracket and stock bushing.
5. Motor Mounts
AKG 24V swap mounts
6. Brake Booster, Master Cylinder, and External Reservoir
New ATE Porsche 944 booster with threaded and shortened shaft, new E32 750 master cylinder with Wilwood proportioning valve, E30 stock master cylinder reservoir. Custom cunifer brake lines everywhere, ABS deleted. Shaved the last 3 intake manifold fins off for a little extra clearance. E36 M3 front calipers, E46 M3 front rotors, E36 M3 rear calipers and rotors.
7. Steering System
Z4 non-powered steering rack with E36 outer tie rods, custom made steering column u-joint with DD slip shaft to mate to E30 airbag steering column.
8. Cooling System
Mishimoto E30/E36 aluminum radiator, E30 late model expansion tank in stock location, Stewart high volume water pump, Fan Man Sidewinder puller fan. Fan motor sits where power steering pump used to be.
9. Exhaust System
Custom 3” turbo back stainless TIG welded, Vibrant resonator under the driveshaft tunnel and a Vibrant 3” in dual 3” out straight through muffler.
10. About a million and a half other things done to the car. It made 596 whp a couple months ago. Heading back to the dyno in a few weeks after making some changes to the fuel, intake, and waste gate systems.
IMG_7349 by Jason H, on Flickr
IMG_7270 by Jason H, on Flickr
IMG_7813 by Jason H, on Flickr
IMG_7045 by Jason H, on Flickr
IMG_8153 by Jason H, on Flickr
Hey guys, since i got my car running i thought i would share my build. Since im from Bavaria Germany parts are plenty. I just have to drive to a wrecker to get everything i need. Everything else can be bought from dealer or ebay.
1. Engine
M52TÜ28B from E46 328ci which broke in half due to rust. got the whole thing for 1.3k, sold unnecessary parts for 800... Engine got a M54B30 intake and a tuned ECU to make it run at 239BHP. Oilpan is a E34 525 one i believe, got this second hand from a Rallye cross car. had several ground contact before so had to fix it with JB Weld. Oilpump schnorchel got re-welded to fit the new sump.
2. Engine Wiring
Bought a Adapter from Bruno Antunes on ebay, helped him do the translation of the instructions. This was a 300€ part. No customization needed tho. Plug and play, runs on every E30.
3. Drivetrain
ZF 5 Speed Gearbox, E36 328i driveshaft combined with E30 automatic center support bearing. Driveshaft needed some cutting (4,7cm shorter). Differential is a E36 compact (No idea about gearing) aswell as the whole rear axle. Wheels are 17" E36 M-Spec.
Lever is a shortshifter from ebay, Linkage is completly OEM
5. Motor Mounts
E28 5-series Motor bearings (70mm)
right side is E36 6 Zylinder engine mount, intake side is a special part from 300mm.de called 24V Adapter. Makes the engine sit perfectly with plenty space in the bay.
E34 525 Tandem Brakebooster and Master cylinder, same goes for the Reservour
7. Steering System
E30 OEM, no Powersteering (just because)
8. Cooling System
E46 328i Cooler, 2.5l Alloy Reservoir from China, Pusher fan from a wrecker Ford Focus or something (don't remember, just ripped it out of a shell)
9. Exhaust System
E36 320i headers, Stainless Steel exhaust system for Motorsport applications ofc flow optimized - has yet to be installed
10. Brake system
Front has 292mm Brembo special brake discs (Special cause they had to fit exactly for this project) aswell as E36 328i Brake Calipers. Got the adapters and discs from Tino's 300mm.de site, he sells whole 5 Stud conversion kits with all parts needed. In the rear i took everything from the E36 compact rear axle and replaced it with new parts.
So in total i spent over 7k in the last 9 Months. Bought the E30 as a automatic for the same i got the Coupè for, swapped everything, had to wait for space and parts or tools. Did everything on my own (except for engine extraction and insertion, so in total i had help twice) No Carlift, just jackstands and alot of me beeing on the ground under the car.
Would i do this again? - No.
Do i recommend this to Novice car guysor hobby mechanics like me? - No.
Did i buy alot unnecessary parts that didn't fit? - Too many...
Is it worth it? -Hell yes.
Maybe i do a follow up story of my build.Comment
m50 1987 325e
Engine- M50 NV from e34 auto. 130kish miles. Completely resealed and installed new t chain guides. Achilles Motor sports weld in baffle, Bimmerworld oil pump lock nut.
cooling- New water pump, t stat and I.E. aluminum rad, spal 16 inch fan, and e36 expansion tank.
wiring- self made adapter harness using m20 plug and e34 body plug. so its reversible if for some reason i want to return to m20.
exhaust- Tubular manifolds customized to a y pipe and a resonator single exit.
Trans- late G260 (swapped my early flange on there) resealed. I.E. DSSR twisted it myself. Condor speed shop swap mounts and trans bracket with garagistic trans poly mounts on the trans. new single mass flywheel and clutch kit for e36.
Brakes- 2009 e90 brake booster and slave with remote reservoir. ( cut, installed new fittings and re bubble flared the lines)Comment
Engine- S52 from 1999 M3
- Replaced seals, spark plugs, rebuilt injectors, chain tensioner, sensors, etc.
- M50 Intake Manifold
- AFe Dry Filter
- Markert Tune, SAP Delete, EWS Delete, 7200rpm Redline
- UUC Underdrive Pulleys came on it
Engine Wiring- Wire harness by Markert Motorworks with wiring for E30 M3 cluster and oil temp sender. Kept it OBD2
Drivetrain- ZF320 from the E36 M3
- E36 M3 Rebuilt Driveshaft
- 3.15 LSD 4 clutch differential from a Z3
Shift Lever and Linkage- Z3 1.9 shift lever
- Turner Shifter Bracket
- E36 328i Shifter Carrier
- Delrin bushings
- Garagistic DSSR
- ZHP knob
Motor Mounts- AKG Poly Motor Mounts
Brakes- BMW X3 Booster, reservoir, and MC
- Porter RS4 Brakes
- Ireland Stainless Brake Lines
Steering System- Z3 2.9 Steering Rack
- Chase Bays High Pressure Steering Line
- E36 Tie Rods
Cooling System- OEM M42 Radiator
- SPAL 16" Pusher
- Stewart High Performance Water Pump
- 82 Degree fan sensor
- 80 Degree thermostat
Exhaust System- Syncro Design Works custom exhuast, added high flow cat in addition to the resonator
- factory headers
More info in this threadComment
