I know the "Comprehensive DOHC" thread is out there, but it is getting very cluttered. I figured posting up complete and running 24v setups might help people with questions they may have on which parts to use on their own swap. Feel free to post your setup and to ask questions.
The following is the way I did the swap in my 318is, but there are MANY options. Hopefully others will post what has worked for them.
1. Engine
I ended up buying a S50B30 OBD-I engine from a guy down in San Diego. I also purchased an e34 525i oil pan, pickup tube, dipstick, and throttle cable (this item I purchased new). While the engine is out of the car I recommend replacing the routine items such as head gasket, water pump, spark plugs, oil pump nut (I used red loctite and a drilled nut), tensioning pulleys, and possibly the VANOS o-rings and spacer. For the VANOS rebuild, I utilized the single vanos rebuild kit from http://www.beisansystems.com/. I also had the head rebuilt at Hopsing Machining in San Diego. He does great work for the price.
2. Engine Wiring
The wiring harness I ended up using was from a e34 525i that I picked up from Autobahn in San Diego. There are many wiring harness adapters that can be used, but I opted to repin the harness into the existing connector using a special BMW repinning tool and new pins. I have a few color diagrams available for those interested. If anyone needs one please feel free to PM me.
3. Drivetrain
I bought a Getrag 260 with a stock 325i driveshaft and a 3.73 LSD. I could have reused the Getrag 240, but opted for the larger transmission because of future plans with the engine. This setup required a swap brace that is rotated 10 degrees which can be attained from white325is on here. I used the e21 320i solid transmission mounts and the Z3M differential mount with the setup as well.
4. Shift Lever and Linkage
To go along with the drivetrain, I purchased a z4 2.5 shift lever and the AKG dual sheer selector rod. Since the transmission was rotated 10 degrees, the DSSR was cut in half and rewelded at a 10 degree angle to match the rotation. I have seen now that UUC is possibly making a "bent" DSSR which would be a great option for people wanting to stick with the Getrag 260. I highly recommend the DSSR. There is absolutely no slop in my shift linkage anymore. I also recommend refreshing the bushings and washers in the shift linkage at this point in time while everything is out of the car.
5. Motor Mounts
I utilized the AKG motor mounts that are solid urethane. Although this is a bullet proof setup, it does rattle the hell out of my car at idle. I would recommend the e28 535i mounts for a smoother ride, but make sure you get the OEM ones for the extra cash. I have heard a few stories of some other mounts shearing in half and damaging radiators and pulleys. Here is an installation guide for the OEM ones: http://www.akgmotorsport.com/e30convinstr2.html
6. Brake Booster, Master Cylinder, and External Reservoir
The brake components I utilized were the e32 735i booster and master cylinder along with the 2002 remote reservoir. No modifications were necessary for the booster and master cylinder. The 2002 reservoir required a remote mounting location and a supply and return line both leading to 2002 plastic elbows shown in the diagram as #12 and #14 http://www.realoem.com/bmw/showparts...08&hg=34&fg=25
7. Steering System
I ended up using the e30 steering lines but heating and bending was required to make them fit. This was not easy and took some time. Just be patient and persistant with this step.
8. Cooling System
I opted to use a e36 radiator with a 16" Spal puller fan for the cooling system. I reused the e30 325i external coolant reservoir and purchased silicon hoses from Rogue Engineering. Before I installed the puller fan, the engine would slightly overheat with a fan delete kit (http://store.bimmerworld.com/e36z3-6...-kit-p582.aspx), so a puller/pusher fan is absolutely necessary. Also do not purchase the water pump shaft nut. Mine didn't fit.
9. Exhaust System
I ended up buying an e36 Rogue Engineering cat-back exhaust from Levent. The stock exhaust manifolds were ceramic coated black and a custom midpipe was put together by RPM in Oceanside with the stock e36 cats (for California BAR purposes). The cat-back doesn't fit well and some custom work on the battery tray needs to be done to tuck the exhaust up a little more, but overall I am happy about the look and sound of the exhaust.
I am extremely happy with my swap! Hopefully this thread helps with some questions people may have. I can also add pictures if requested. Thanks for looking.
-Ian
1. Engine
2. Engine Wiring
3. Drivetrain
5. Motor Mounts
7. Steering System
8. Cooling System
9. Exhaust System
-Ian
