Do I need a check engine light to be able to get my car BAR'd with an OBD2 S52 swap? I have an '87 325e, so I don't have a cel at the moment.
California OBD2 Swaps, Check Engine Light?
Tags: None
So I need to install a CEL light I guess. Or swap over an entire late model cluster, since I'll already need a new tach.Last edited by coreyw; 08-07-2012, 06:20 PM.Comment
you need it even with obd1. it's just a light bulb that's grounded by the dme.Mtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
OEM v8 manual chip or dme - https://www.r3vlimited.com/board/sho....php?p=4938827Comment
Your harness has a CEL wired ;)
Check Us out on Facebook
Full Product Line Tuning
OBD2 Tuning Available! OBD2 E36, S54 Swap, S62 Swap, etc: tuning@MarkertMotorWorks.com Dyno ThreadComment
CA referee's are notorious for being very invasive, by the book, front to back compliant with no "slack" to be given. It's their job they're protecting, (especially in this economy) so the word "meticulous" is an understatement. Of course you need a functioning CEL!Comment
I'm running a 24 valve swap and I just went to the bar to legalize my swap he checked everything including a stomp test of the mil light he wasbuy the book on everything the only thing he didn't care about was the cold air intake it had no carb sticker and I live in CaliforniaComment
