Yeah, I did some simplifying of the wires and some forcing but it's on there now. I.realize now how much longer than necessary I made my wiring going from the harness to the c101. Some time when I'm more anbitious I'll shorten those up and get rid of unused ones.
fitting m50 wiring under 318 harness cover
For all things 24v, check out Markert Motorworks!Originally posted by mbonanniI hate modded emtree, I hate modded cawrz, I hate jdm, I hate swag, I hate stanceyolokids, I hate bags (on cars), I hate stuff that is slowz, I hate tires.
I am a pursit now.
solder + engine bay heat + vibrations= electrical grimlins. Notice the factory doesnt solder anything short of circuit boards?
Check Us out on Facebook
Full Product Line Tuning
They don't solder things because of time and efficiency with oem crimping tools and terminals. Trust me I have done enough wiring to know that a proper solder joint and heat shrink is many times better and cleaner than using butt connectors. If your engine bay is getting hot enough to melt solder to the point that your joints fail, it means you have way more serious issues to worry about, or are terrible at soldering. This isnt even taking into consideration the propensity for exposed copper wire to oxidize in open air crimp splices.
Also in the after pic you can see that I have 2 sets of splices offset and tons of room for the cover to fit, the wire bundle actually fits in the space behind the relays.Last edited by chrisbmx68; 09-18-2012, 06:53 AM.
1988 325is S50 in-progress.
http://www.facebook.com/E30LocalCrew
Few pictures:
http://www.r3vlimited.com/board/showthread.php?t=255061
Originally posted by 328ijunkie View Postsolder + engine bay heat + vibrations= electrical grimlins. Notice the factory doesnt solder anything short of circuit boards?
any detail which wire shortened or lengthened?
so the wiring can reach 318i ECU bracket and fit with 318i wiring cover
r3v member "lifeiskaos" did very nice wiring modification as below pic
[ETA - E30 Adapters] 5 Lug kit with e46m3 front and e46 325/328i rear brake setup
[ETA - E30 Adapters] - 5 Lug kit | DTM Shifter | DSSR
Transaction Feedback
