OBD2 S50 up and running!
  • 328ijunkie
    • May 2007
    • 3961
    #46
    Remove the crank sensor adapter harness completely. Plug vanos solenoid directly into fuel rail.
    M50/M52 TBs are interchangable electrically.
    Check Us out on Facebook
    Full Product Line Tuning
    • S.Low
      • Dec 2015
      • 26
      #47
      OK great I think that was the last piece to my big question mark.
      I hope the throttle cable on the 328i is long enough then.
      Thank you so much, I'll let you know how it goes after engine goes in this Saturday.
      • dude8383
        • Jan 2005
        • 10387
        #48
        The 328i cable should reach. We just completed an S50 running OBD2 in a 318ti with the help of 328ijunkie :up:
        • 328ijunkie
          • May 2007
          • 3961
          #49
          Good luck, LMK if you need some help with the tuning side of things ;)
          • S.Low
            • Dec 2015
            • 26
            #50
            Awesome. I haven't driven my car in awhile. cannot wait till its running again.
            thank you so much for the help. i'll keep you updated on how things turn out.
            • S.Low
              • Dec 2015
              • 26
              #51
              Quick update. It does run @328ijunkie. Thank you so much.
              But. There's always a butt. I reused one of my oil pumps from one of my spare parts engine. Obviously unknown condition. So. Low oil pressure at idle.
              I should have reused my oil pump from the engine out of the car. Smh.
              Will be changing out the oil pump this week someone. Hopefully that hits the spot.
              Thank you again!
              • 328ijunkie
                • May 2007
                • 3961
                #52
                Hate it when that happens. Good luck getting it sorted!
                • S.Low
                  • Dec 2015
                  • 26
                  #53
                  Got that low oil pressure issue fixed up. But yet another issue.
                  Misfiring under load and sometimes just trying to open the throttle.
                  I'm assuming Harness and coil packs are good since they were on the car and were fine before I pulled the engine 2 months ago. I'm pulling my hairs once again. Plugs look fine also.
                  I am using the obd1 throttle body and no 2ndary air pump. That's all I've changed from stock.
                  As far as engine timing. I triple checked it and everything ligned up after rotating the assembly.
                  Anyone had these issues after doing this conversion? Any tips on where I should be looking at?
                  Any help greatly appreciated
                  • S.Low
                    • Dec 2015
                    • 26
                    #54
                    Actually runs waaaaaay better when engine cold. Once it gets closer to operating temperature it starts to to bog out like stated above.
                    • S.Low
                      • Dec 2015
                      • 26
                      #55
                      Ok. Make sure to plug in your O2 sensor to the right plugs. Or your car bogs out after warming up.
                      Flipped the plugs and seems to run and drive fine. Went for a quick test drive and it went well. Didn't drive around too long as it's dark out and I don't have a front end on or any lights lol.
                      • dude8383
                        • Jan 2005
                        • 10387
                        #56
                        Was going to suggest that you had swapped em around. Had the same problem on our end too.
                        • 328ijunkie
                          • May 2007
                          • 3961
                          #57
                          :p
                          • S.Low
                            • Dec 2015
                            • 26
                            #58
                            Yeah I'm glad that turned out well. I didn't have an obd2 scanner with me I was growing gray hairs almost.
                            Will be putting the front end back together and maybe some action shots
                            • S.Low
                              • Dec 2015
                              • 26
                              #59
                              I feel like such a nuisance lol. Now I'm getting codes thrown at my face. Had code for bank1 & bank2 O2 sensors obviously from when I had hem flipped. Misfire cyl4. Cleared them been driving around and scanned it again. P0340 cam sensor and P0121 TPS comes up now. Slight hesitation while cruising partial throttle. Very prominent at freeway cruising.
                              I'm using the obd1 dinnan throttle body from my old 325i which was working well. I cannot imagine that going out unless someone dropped it when it was sitting at my place.
                              As far as the cam sensor. It came off the engine originally in the car which everything was fine till the rod knock.
                              Any thought on this. No misfire code yet
                              • 328ijunkie
                                • May 2007
                                • 3961
                                #60
                                Cam sensor needs to be replaced and you have to have a tune for the throttle body.
