s52 intake manifold under boost
  • bender
    • May 2004
    • 171
    I realize the best situation is to swap back to the s50/m50 manifold and OBDI.
    I am going to be running standalone on my engine, so I'm not really concerned with OBDI.
    Would it still be nessicary to swap back to m50 manifold if i'm going to be boosted? Will i still see the powergain? or is it not as important..
    Thanks!
    600hp beast
  • gstuning
    • 833
    yes there is strong powergain with the M50 mainfold as it flows alot better thus more power
    Gunni
    @ Prodrive / Aston Martin Racing
    • bender
      • May 2004
      • 171
      ok cool. Just wasn't sure if being under boost changed any of that... I would think it would somewhat?
      600hp beast
      • Addissimo
        • Mar 2004
        • 1820
        being under boost amplifies it. Thats part of the reason so many people opt to make custom intake manifolds when going FI.
        Which stand alone system are you using?
        Doing something M50 related? -> http://www.addissimo.com
        On Myspace? ->http://groups.myspace.com/r3vlimited
        BF2142 SN = BillyGoose
        • equate975
          • Jun 2004
          • 3382
          Someone should figure out how much boost a m50 intake manifold can take before it explodes :)
          Rollin' with a Geistkuchen
          • bender
            • May 2004
            • 171
            Addissimo - I'm going to be using VEMS.
            600hp beast
            • Addissimo
              • Mar 2004
              • 1820
              Damn.
              That looks like a pretty awesome system. I wish I would have known about that before I purchased the SDS system.
              I'll definately look into using that for the next car I build. I love the sequential fuel and ignition!
              good choice!
              -Addis
              • bender
                • May 2004
                • 171
                yeah, i have the previous VEMS unit on my rabbit running EDIS ignition and its great..
                The newer version of VEMS is awesome and should be able to handle the S52 with no problems, including VANOS.
                600hp beast
                • grapedrink
                  • 1514
                  Here is another question.
                  Who makes a controller that can handle 12 cylinders?
                  Originally posted by DaveCN
                  Welcome.
                  Your car is a piece of shit.
                  Most of them here are, too.
                  • Addissimo
                    • Mar 2004
                    • 1820
                    VEMS can, though it looks like you'll have to go wasted spark/batch fire injectors.... not a big deal though.
                    -Addis
                    • Ryan Stewart
                      I Love Miatas
                      • 8978
                      enough to make more power than you can handle. So far I have seen 12lbs go through an S50B32 and its a fucking deathtrap.
                      Im now E30less.
                      • kylebes1
                        • May 2004
                        • 2804
                        Yes, considering I would kill to merely drive a s50b32 with almost a bar of boost.
                        • Digitalwave
                          is a poseur
                          • 6287
                          AA does 25+ PSI S50's with the stock intake manifold, I don't think you could actually make it explode.
                          RISING EDGE
                          • 1990m3
                            • 1180
                            lots of companies use plastic intake tubing for their turbo setups because the plastic retains less heat than the metal piping. I don't think there is much of a problem at all with using plastic under boost
