Swap 1/4 Mile Thread
    Originally posted by Wanganstyle View Post
    perhaps lower rear tire pressures and try a 2 stage clutch launch like an AWD car?
    I was running 15 psi in the r-comps, 35 in the street tires. Not sure what you mean by a two stage clutch launch.
    Originally posted by samiam3356 View Post
    Are you lifting and shifting or keeping the bitch pegged?
    I'm lifting for 2nd (probably not enough, as it does spin into 2nd), and lifting just enough to keep it from bouncing off the limiter in 3rd, and basically keeping it floored into 4th (which is irrelevant, I'm 99% sure I'm across the line in 4th. 7000 RPM's is 95mph in my car, and that's what I trap at, which is also my redline and what I shift at, but I stay in it until 100 or so).
    e30 restoration and V8 swap
    24 Hours of Lemons e30 build
      if you are launching an AWD car (esp one with turbo), the launch technique ends up being a 2 stage affair -subaru loves to blow up transmission on launch, so this is another reason - its also very easy to bog if turbo not loaded enough!
      -usually this is done to pre-load the driveline as the tree goes from yellow-yellow with the first stage of clutch let up also spooling turbo like brake boosting.
      the second stage of release is to take off and fight bogging paired with more throttle, if you were running super low PSI and bogging a bit with 2wd perhaps a 2 step clutch launch MAY help. May not lol
        .2 (faster)was about the difference between powershifting every gear w/spinning and lift/shifting. Albeit on a straight axle mustang.
        Originally posted by Roysneon
        $5 shipped?
        Originally posted by MarkD
        You are a strange dude, I'n not answering any more posts from you.
          Which was faster?
          I noticed when I ran the v710 r-comps, I barely lost any of my acceleration rate with the spinning induced by powershifting. The slip angle (not sure what you'd call it in terms of straight line traction) of v710's is pretty high, so even though they were spinning, the car was still accelerating almost as fast as it would if they had full traction. With street tires however, there was a noticeable decrease in acceleration rate with the spinning into 2nd gear, when they finally hooked in 2nd gear it threw me back in the seat, telling me I lost a lot while I was spinning.
            Not lifting was faster, every single gear
            $5 shipped?
              Last week I ran my car at PIR. Just a bit slower than my run last month at the Woodburn track but good runs none the less. There was a new 335i there too and I was beating him by a few tenths. Here is last week at PIR:
              And last month at Woodburn:
              1989 325i Alpine s52 coupe
              2003 540i M-Sport 6 speed
              2003 X5 3.0
                What modds? very nice.. (borat voice) Im dumping a s52 obd1 in me car, would love to see high 13's!
                  That's amazing. Your 13.0 is awesome, even with a 2.0 60'. But your 107 trap speed blows my mind. What's done to the s52? Did you dyno it?
                    My donor car was a 95 M3 that had already been S52 swapped. I knew very little about the mods done to it and I was surprised to find some goodies when putting it in my car. Aluminum flywheel, oil pump nut already welded and a wax plug in the back of the head indicating a rebuild. This all told me somebody had put some thought into the build of this e36. There was a Dinan chip in the car but it had ews (i tried it). I got a TRM chip for pink injectors, stock MAF, aluminum flywheel, 7k rpm. I am very impressed with the time I put down. Seems to be one of the quicker NA street car swaps out there. I am running the zf320 with 3.46LSD.
                    We are throwing a dyno day at HPF in portland on 10/22. There will be several e30s including other s52 cars there so I will get a feel for what else is done or how healthy the engine is.
                    -Mac
                    2003 X5 3.0
                      Damn, you're lucky!
                      $5 shipped?
                        What is amazing to me...is that you picked up 1 mph on the big end, all else being equal.
                        On paper, that's a 10 horsepower increase.
                        Ed
                        1988 E30/S50...now with S52; Track
                        1994 Miata R; ES Solo2
                        1998 Lexus LX470; Wife (Slee'd anyway)
                        2002 BMW 530i; A+ Commuter
                        2002 BMW 325iT; Sport/Premium 5-speed
                        2011 21' EconoTrailer
                          13 flat is QUICK. That's E39 M5 quick.
                          How'd it hook? Any traction issues?
                          paint sucks
                            It hooked up suprisingly well. much better than it does on the street. I couldnt dump the clutch or anything but I also didnt really have to feather the throttle. I do have a sub box from Luke in the trunk to help with traction and hurt my trap ;).
                            -Mac
                            2003 X5 3.0
                              This should really be here for posterity:
                              Originally posted by leothedrummer View Post
                              Taken from another forum:
                              Since you asked so nicely, here are my thoughts. I've assumed the following:
                              + Street radial tyres
                              + Pump fuel
                              Setup For Drag Racing - Weight Reduction
                              First setup you car before going to the strip.
                              Your first task is weight reduction. Ensure you get to the strip with 1/8th tank of fuel. That means allowing enough fuel to get there with 1/8th left. Better to arrive with too little fuel and then topping it up a tad from your jerry can, which is of course filled with the same 98 RON fuel you have in your tank. A properly mixed slug of octane booster will give you some peace of mind too. Remember to put the booster in first to allow the petrol to mix with it properly in the tank.
                              Every 1 litre of fuel weighs 640 g.
                              Next drain all the water out of your washer botle. My M Coupe takes 5 litres in the washer bottle which is 5 kgs you don't need.
                              Then remove the spare tyre, toolkits and anything else from your boot and from inside your car. Anything that can be eaily removed should go (CD Stackers, carpets, lose stuff, etc).
                              Now decide if you want to go to the trouble of removing your rear seats and passenger seat. Believe me when I tell you it will make a big difference. On average they say every 100 lbs (~45 kgs) is a tenth (0.1 off your ET).
                              Setup At The Strip - Tyre Pressures
                              Now you've driven to the strip and been through scrutineering, get out your trusty pass journal and tyre pressure gauge.
                              Ensure you've got 1/8th tank of fuel - you don't want to starve for fuel during a pass. Now hook up your compressor and increase your front tyres to 55 psi. If you don't have access to a compressor then swing by the closest servo to your drag strip and do this before you lob at the strip.
                              You increase the pressure in your front tyres to minimise rolling resistance. If you happened to have an alternate set of narrower wheels/tyres then you'd fit the narrowest practical set for race day.
                              The rear tyre pressure is more involved, because you've got to try a range of pressures and see what results in the best 60' times. The optimum setting changes as the weather conditions change, so this is a bit of a black art. That's what your Pass Journal is all about. This is where you record your car setup and the results after each run. That way you can make changes one at a time and make some sort of analysis in order to optimise your setup.
                              Generally speaking you should drop your rear tyre pressure 4 psi from standard and then work your way down by half a psi at a time until your 60' times get worse.
                              Remember that fine adjustments on street radials is less of a factor than when you graduate to drag radials or slicks. However it is still well worth your while to get close to the optimium.
                              Your Pass Journal will have an entry for every pass you do, including the following information as a minimum:
                              + Tyre pressure
                              + Launch RPM
                              + 60' result
                              + My comments
                              More on how to use your Pass Journal seek the optimum setup in a later post.
                              The Burnout - How Long?
                              If you are a beginner or feel a bit nervous about the upcoming pass, then simply drive around or through the water box and don't worry about a burnout. You can add the burnout to your later passes as you become more comfortable.
                              Remember that street cars using street radials are very different to a Top Doorslammer. You're not going to do a half track burnout and wow the crowd. Street cars that do long pointless burnouts are basically wasting everyone's time. Don't be one of them!
                              Now street radials like a touch of heat in them to get optimum traction. But too much heat and their traction is reduced. However if you don't spin the tyres at all then you've still got some water and grit on your tyres from the water box (unless you managed to drive around it).
                              My advice for street radials is to drive through the water box and come to a halt. When signalled by the official, dial up the revs and drop the clutch. Wait until your tyres smoke a tad and then button off. We're talking less than a 2 second burnout here. More than that and you risk cooking the rubber (ie reducing traction until they cool).
                              Realise that drag radials and slicks are made totally differently to street radials. These special tyres require a lot more heat to work. Street radials don't.
                              The Burnout - How To Do One?
                              Now you know how long to let the burnout go for, exactly how do you perform a decent burnout?
                              Let's start from standstill, waiting for the official to motion you to start your burnout. Select the appropriate gear (1st, 2nd or 3rd depending on your horsepower, the higher the gear the more power required to turn the tyres over). When the official signals to start your burnout, dial in some revs and drop the clutch. You can dance your left foot over to touch the brake a tad and balance the revs via throttle with forward movement via brake (takes a bit of practice).
                              Now if you continue to creep forward and start to contact your tyres with dry sticky track then you're obviously going to put more strain on your driveline.
                              When you've got some heat into the tyres, just let off the brake and /or drop revs a tad and your car will creep forward. Get off the gas and allow the car to roll gently towards the staging lights.
                              How To Pre-Stage
                              You're rolling gently towards the staging lights. Keep your eyes on the Christmas Tree and look for the White Pre-Stage light to blink on. The instant you see this light come on you nail the brakes and come to a total halt. You're not yet fully staged - just pre-staged. The second Full Stage light is still unlit.
                              I recommend you now wait until your opponent is at least Pre-Staged or even on Full Stage before you bump in to Full Stage. Once either compeitor is on Full Stage, the other racer has only 20 seconds to fully stage or the starter may disqualify you. In practice at a street meet the starter will rarely disqualify you, but they may come over and bang on your side window to hint that you're holding things up!
                              Once you are pre-staged you must now focus on that Full Stage light with all your concentration. Because as soon as you fully stage, the starter can trigger the Christmas Tree at any time.
                              How To Bump On To Full Stage
                              You're at a halt with the Pre-Stage light up and your competitor is fully staged.
                              Now apply your handbrake gently and dial up your pre-determined launch RPMs. You've already thought about what RPM you're going to launch at before you lined up. If this is your first pass, then just choose whatever starting point you think appropriate.
                              Your clutch is in, your RPMs are steady at your launch point and your handbrake is slightly on. Now you ever so gently tease your clutch out - looking for the friction point where the RPMs start to dip showing you the clutch is dragging you your engine just slightly.
                              With your left hand you are holding the handbrake just slightly on. This is a delicate balancing act, ensuring your engine is at launch RPMs, your car rolls forward ever so slightly and your rear brakes are just slightly on to ensure you move very very slowly on to Full Stage.
                              This is called bumping on to Full Stage and is not easy to do. If you roll forward too far you will Redlight by crossing over the start beam. No big deal, it's all practice and you'll do better next time.
                              Once you bump on to Full Stage you pull your handbrake up firm so your car comes to a dead stop. But you don't allow the handbrake to ratchet on lock, you keep it on but not locked by pressing the button as you hold it.
                              If you get it right you will find yourself fully staged, motionless on the start line and most importantly, you are solidly locked on your launch RPMs with your clutch just at friction point, dragging against your handbrake.
                              You are not looking at your tacho to check your RPMs. You are not looking at your handbrake. You are not looking at anything other than the Christmas tree.
                              The Launch
                              It's been covered in detail in many other places so I'll just state it here. Because of human reaction time and because of the vehicle reaction time of your car's suspension and drivetrain, you do not launch when you see the Green light on the Christmas Tree. You launch the instant you see the last of the three Amber lights come on.
                              You're at steady launch RPMs with the clutch at friction point and the handbrake held on but not locked. As you see the last Amber come on, you release the handbrake fully (holding the button in), progressively mash the throttle and modulate your drivetrain using your clutch.
                              This is not easy to do and takes many repetitions to get a good result. This is where it's all at - your reaction time versus your opponent and how well you can launch your car without wheelspinning.
                              You must slip your clutch mercilessly to get an optimum launch. Sometimes you may find you have not let the clutch out fully before it is time to change up a gear. This is OK.
                              Wheelspin on launch or upshift will cost you precious time. The optimum launch is at 10% wheelspin. This is very difficult to achieve and again comes only with much practice and experience. It's all good!
                              Yes, you will punish your clutch. Yes, it will give off that awful smell of tortured components. Yes - it is the only way to optimise your launch.
                              Clutches are consumables and are meant to be replaced. Regular drag racing will severely shorten the life of your clutch, but so what? You replace the clutch and go on your way. Just like tyres.
                              Getting A Better Time
                              Your reaction time (RT) is all about how quickly you react on the start line. It does not factor into your ET at all. However the winner of each race is very much affected by the RT. So once you are comfortable with the process of doing the burnout, launching and shifting up through the gears I recommend you treat each pass like it's a race. The only way to get better is to practice like you race.
                              Drag racing is all in the launch. Every tenth (0.1 second) reduction in your 60' time is .15 to .25 reduction in your ET.
                              You can beat an opponent with a much more powerful car by getting a sharp RT and by getting a sweet launch.
                              That will do for now, happy to answer any specific questions or prate on about any area in more detail if desired.
                              HTH
                              '89 Alpine S52 with goodies
                                Well I just ran. First time running this car, only ran FWD cars a few times before this. 13.4@ 105 with a 2.1 60 ft. It just spun through second, tried lifting but kept spinning. Car is 2715 with me in it, I'm about 155. I ran against a new Camaro that ran 12.7 at 106, once I stopped spinning he wasn't going anywhere. There is definitely more in this thing, just need to learn how to drive. :D
