Mishimoto with 16" Spal Puller Fan Fitment
  • ian e30 318is
    • Mar 2007
    • 1809
    I am hoping someone can answer this for me. My stock e36 radiator is starting to leak and I want to replace it with a Mishimoto.
    Will a 16" Spal puller fit with an e36 3-series Mishimoto? http://vr-speed.com/store/mishimoto-...99-p-2103.html
    If that won't work, can I go with the z3 Mishimoto radiator and a puller? http://vr-speed.com/store/mishimoto-...2-p-20098.html It appears to be 2.9" thick instead of 3.5" thick.
    If neither will work I will just rotate the blade on the puller, remove the AC condenser, and run it in front. Thanks for the help.
    -Ian
    1991 LS1 Swapped 318is
    Instagram:
    https://instagram.com/saltybeast/
    LS Build Thread:
    https://www.r3vlimited.com/board/for...s-e30-ls1-swap
  • ian e30 318is
    • Mar 2007
    • 1809
    No one has this setup??
    Instagram:
    LS Build Thread:
    • 325Projectz
      • Jan 2005
      • 1956
      check this - http://massivebrakes.com/accessories...al_16_adapters
      some people make their own adapters to make this work. i think janderson did it. not sure which fan he's running.
      91 m3
      • 325Projectz
        • Jan 2005
        • 1956
        cancel that, they mounted them up front... - http://www.r3vlimited.com/board/show...adiator&page=2
        maybe someone else will chime in.
        if you don't have a/c, i'd pull the condenser out anyway and mount the fan up front. you're pretty limited on space for a puller fan however some guys are running mechanical fans. you'd have to search. keep in mind the mishimoto radiators are thicker than the m42 rads that a lot of people are running, reducing your space behind the rad even more.
        91 m3
        • Slovik
          • Jan 2010
          • 198
          I don't think you will have the room for a fan that thick, I went with these for just that reason http://dnamotoring.com/store/index.p...-mounting.html along with the CX racing aluminum rad, it just barely fits but it works very well.
          • ian e30 318is
            • Mar 2007
            • 1809
            Yeah I already have brackets to mount the Spal fan and the 16" fan. I am currently running it in front with a Bahr radiator. My question is will the fan fit? I guess I'll just buy a Mishimoto and figure it out lol. Thanks for trying to help :D
            Instagram:
            LS Build Thread:
            • smooth
              • Apr 2005
              • 1940
              If you want another stock e36 radiator let me know and I'll sell you one inexpensively from my donor car. It looks immaculate. I can take pictures/video of it if you'd like.
              Das ist nicht nur nicht richtig, es ist nicht einmal falsch!
              • ian e30 318is
                • Mar 2007
                • 1809
                Thanks for the offer but I think I have my mind set on the Mishimoto. I've heard great things about them from friends.
                Instagram:
                LS Build Thread:
                • smooth
                  • Apr 2005
                  • 1940
                  Not a problem. If you've got the funds I'd go for an aluminum radiator, as well. In fact, that's what I did :)
                  • butters
                    • 1206
                    bump - did you get the puller to fit with the E36 radiator?
                    • bigdrick323
                      • Feb 2012
                      • 616
                      How do I mount the 16" spal pull fan in front of the condenser?
                      sigpicMy Project!
                      Official North Texas Bimmers Club E30 Representative
                      www.BimmerAlliance.net
                      "If you have questions about events or need help in the DFW area don't be afraid to contact me."
                      • pandaboo911
                        • 2070
                        Do you track your e30? if so don't bother with a mishimoto.
                        • robgoesvroom
                          • 821
                          Why not use the mishimoto rad with an S50/S52? Just curious, I'm planning out my build for an S52 and already have this radiator. Been tracking the M20 with this radiator the past 2 years and would like to plan ahead.
                          TIA
                          • JCarp90
                            • Feb 2011
                            • 1759
                            Also curious.
                            If spending the money is not an issue, it's peace of mind.
                            • bigdrick323
                              • Feb 2012
                              • 616
                              Is this in response to me?
                              Sent from my LG-MS870 using Tapatalk 2
                              sigpicMy Project!
