MAF Sensor Question
  • MR E30 325is
    • Dec 2008
    • 3300
    MAF Sensor Question
    Is there a difference between the MAF sensor used in the stock OBDI MAF's that come in the M5x/S5x equipped cars and the sensor that is inside of the 3.5" MAF that we all want to upgrade to?
    I want to know to potentially save myself some money when it comes to upgrading my intake system. If I can simply buy the larger housing and swap my current sensor into it, that would be much easier than trying to find, or buying a brand new sensor.
    Thanks!
    My previous build (currently E30-less)
    http://www.r3vlimited.com/board/showthread.php?t=170390
    A 2016 Toyota Tacoma TRD 4x4 Offroad in Inferno is my newest obsession
    • 34835
    my first question is, why do you think you need a bigger MAF?
    • M3PO
      • May 2012
      • 537
      As far as I know, that won't work. The sensor is expecting to be in a certain size housing. When you change the size of the housing, the "calibration" is off. The DME will think it's getting a smaller amount of air than it is.
      • MR E30 325is
        • Dec 2008
        • 3300
        More airflow my man! An engine is basically an air pump, so being slightly intuitive, getting more air in would yield power gains......
        M3PO - There would be a tune for the bigger housing. I am going to do some research and actually look up the part numbers.
        I did this swap on my 3.5" hfm equipped M3 and my stock sized OBDI sensor from my current S52 E30, and it worked just fine. I just wanted to double check.
        • DREWHALL
          • Feb 2006
          • 1207
          Your car looks angry.
            • 34835
            or more placebo effect..
