So if i got the harness with the motor, what work do I need to have done to it for an OBD2 swap? I am just not sure what you had Markert Motorworks do with the harness.
					DIY: In depth M52/S52 OBD2 swap
what did you end up doing for the oil temp and pressure sensors? I only have one sensor (pressure i believe) on filter housing on my S52, trying to figure out what the best option is to get temp sensor (and what part # for sensor). Looking at Rally Road block
I used that block off from a different manufacture and it works well.
Sent from my iPhone using TapatalkComment
