maf problems
  • evoDRichie
    • Jan 2010
    • 1743
    maf problems
    with an unplugged 540 maf my s52 runs SUPER strong.... with it plugged in, it runs like ass no power, bucks, just no good. i got another maf and it does the same thing, so i tried a 3rd one, still no change... whats up anyone have any advice???
  • butters
    • 1205
    were those 2nd and 3rd mafs from an S52, or were they other 540 mafs? if the 540 maf is the commonly used 3.5-inch "high flow" maf, I could see issues without the right tune. I'd recommend the OE maf, many agree the 3.5" maf is not worth the trouble because the real bottleneck is the throttle body.
    • evoDRichie
      • Jan 2010
      • 1743
      Its obd1 swapped with a tune for a 540 maf so ... it worked fine for the last 4 months then one day it didn't
      • evoDRichie
        • Jan 2010
        • 1743
        any input im still running with an unplugged MAF... so far the only thing that has changed is more power
        • ForcedFirebird
          • Feb 2007
          • 8300
          Check continuity from the MAF plug to the ECU plug and make sure you have power and ground at the plug with key on.
          Can also test voltage of the outputs of MAF to ECU. Should see somewhere around 1v at idle.
          john@m20guru.com
          Links:
          • evoDRichie
            • Jan 2010
            • 1743
            did all that everything seems fine, i tried another maf and it worked kinda ok no power but to cut out...then i had to unplug the dme and unplug the maf to make it run good again...
            • 328ijunkie
              • May 2007
              • 3961
              Do you have a tune for the 3.5"?
              Check Us out on Facebook
              Full Product Line Tuning
              • cormier
                • 380
                I would double check the tune since you've swapped it so many times with no change
                • evoDRichie
                  • Jan 2010
                  • 1743
                  yep it ran fine before for months
