OBD1 S52 in '91 318is, no crank, no start
  • Robert
    • Dec 2010
    • 3770
    Are you sure the engine can spin freely ? Check all grounds & the starter to power cable.
    Make sure their isn't any type of killswitch (alarm)
    • TheRealE30kidd
      • Jul 2010
      • 496
      Thats where we are at now the Crank does not spin freely. Something is jammed up!
      The Current Army
      -(UnderConstruction) 1991 330iS 24v S52 build thread
      -1992 325iC
      -1987 E30 Truck
      -1991 332iS (BecauseRacecar)
      -1988 Dinan M3
      -1988 325iX Tribute car
      -1989 320i Touring (S52/6spd)
      • cormier
        • 380
        Oh no! What was the motor history?
        • Robert
          • Dec 2010
          • 3770
          First thing I would check is the clearance between the flywheel and oilpan. M20 flywheels with e34 oil pans tend to touch unless shave and spaced.
          • TheRealE30kidd
            • Jul 2010
            • 496
            Tranny is coming off tomorrow!
            The Current Army
            -1992 325iC
            -1987 E30 Truck
            -1988 Dinan M3
            • 10Toes
              Me Father Was A Tree
              • Jan 2008
              • 61222
              Damn, did 5Toes work on this thing.
              • brenE30
                • Aug 2009
                • 120
                im gonna have to agree with everyone on the flywheel. i had this same problem in my 87 4door, flywheel was shaved but when we got it back and all installed, put back in the car i would get the same click and nothing. turns out the shop only shaved it half of what we asked for. it was corrected and re installed, worked no problem
                • 328ijunkie
                  • May 2007
                  • 3961
                  Have you tried hotwiring the starter and seeing if it fires.
                  Check Us out on Facebook
                  Full Product Line Tuning
                  • e30austin
                    • 15382
                    My thoughts exactly at this point. It was already shaved and appeared not to have any issues, but that's obviously not the case now...
                    • TheRealE30kidd
                      • Jul 2010
                      • 496
                      :hitler::hitler:
                      The Current Army
                      -1992 325iC
                      -1987 E30 Truck
                      -1988 Dinan M3
                      • dashboardmonkey
                        FUCK YOUR WAFFLES
                        • Jun 2008
                        • 6158
                        When i did my swap. I had the shop shave my m20 flywheel down to the ring gear. No spacing needed
                        -Andy
