24V Radiator Options
  • ian e30 318is
    • Mar 2007
    • 1809
    I am looking at a radiator that cools better than stock, but not an $800 unit like the Zionsville radiator. The two I am looking at are:
    1. Mishimoto e36 Radiator http://vr-speed.com/store/mishimoto-...99-p-2103.html
    or
    2. Champion e30/e36 Radiator http://www.andysautosport.com/bmw/19...d00000170.html
    Anyone have any opinions or experience (good or bad) with either? I was expecting to go with a Mishimoto until I saw the recent thread about the cracks.
    Thanks!
    -Ian
    1991 LS1 Swapped 318is
    Instagram:
    https://instagram.com/saltybeast/
    LS Build Thread:
    https://www.r3vlimited.com/board/for...s-e30-ls1-swap
  • 10Toes
    Me Father Was A Tree
    • Jan 2008
    • 61222
    The mishimoto is a good radiator and they have a good warranty, if you are really worried about cooling they make a even bigger radiator, the X-line. I got my X line for under $300 shipped.
    As an ideal upgrade to the stock BMW radiator, the Mishimoto BMW Z3 X-Line aluminum radiator will give your BMW a cooler engine that runs more efficiently, boost engine functions and prevent your car from overheating. All Mishimoto X-Line performance radiators are made with durable aircraft quality aluminum and feature polished end tanks. As with all our aluminum radiators, this BMW Z3 radiator includes the Mishimoto Lifetime Warranty.
    I have never looked at the champion before but if the core is 2" like it says (the normal mishimoto is 1.57") and a 3 row then it should cool pretty good and the price is about the same as the standard mishimoto.
    • ian e30 318is
      • Mar 2007
      • 1809
      How are you liking the mishimoto z3 X-line so far? It fits pretty well?
      Instagram:
      LS Build Thread:
        • 37832
        Curious why you need better cooling than stock?!
        My S50 car stayed nice and cool with a little M42 radiator even on 100 degree days.
        Classic BMW Specialists
        Grover Beach, CA
        www.BimmerHeads.com
        • ian e30 318is
          • Mar 2007
          • 1809
          I have had two stock radiators leak on me. Its not that I necessarily need better cooling, its that I want better quality. I have had the temp creep a few times with the stock radiator and a fan though, so better cooling would be a good addition.
          Instagram:
          LS Build Thread:
          • Roysneon
            • 4505
            If you need to replace your rad, the warranty alone on the Mishi is worth it. Plus you can get up to 100 fuh raze points with it.
            But seriously sounds like a good investment to me.
            Originally posted by mbonanni
            I am a pursit now.
            • blackhawkimpact
              • 2415
              Im using the stock m42 rad and it cools fine. No leaks
              • Lof8
                • Oct 2006
                • 2827
                My vote is Mishimoto. I've been running it for three years, two with heavy track use - no complaints at all. The only fan I have is the A/C fan.
                S50'd
                Originally posted by TDE30
                What is this faggy shit I have happened upon?
                I can always live in a M3. Can't M3 a house.
                • lbreevesii
                  • Aug 2009
                  • 412
                  gotta say, my nissens m42 rad has been working fine in the S50. i'd recommend a hole in the top of the t-stat to help bleeding, but it seems to be a pretty solid setup. I'm using a spal pusher that replaced the aux fan on mine.
                  I don't always wreck cars, but when I do I wreck them into trees.
                  91' 318is S50 swap - The Black Widow
                  • ian e30 318is
                    • Mar 2007
                    • 1809
                    Did you drill the hole? How large?
                    Instagram:
                    LS Build Thread:
                    • ian e30 318is
                      • Mar 2007
                      • 1809
                      Yeah I think Im going to go with a Mishimoto. Which one are you running?
                      Instagram:
                      LS Build Thread:
                      • Lof8
                        • Oct 2006
                        • 2827
                        I'm pretty sure its the regular e36 version.
                        S50'd
                        • luckysnafu
                          • Jun 2008
                          • 262
                          1/8 inch at 12-oclock on the t-stat
                          M/S52 Wiring Diagrams
                          Z3M S52 to late model 325i wiring diagram
                          M52 to 318is wiring diagram
                          • butters
                            • 1202
                            While on the subject, can anyone explain the 2-row vs. 3-row aspect? Are "rows" flow paths across/through the radiator (driver to passenger side) stacked in front of / behind each other (in the thickness 'dimension')? I have trouble visualizing this. The champion 3-row is the same price as the mishi 2-row, but I'm not sure how the 2" thick core will work out with a slim puller fan.
                            Off topic of the thread but to add my 2 cents on the M42 aspect: some people have success with the M42 radiator, I chose to stick with mine to see how it goes and if I can avoid the external expansion tank. I do not recommend it if you want to use your car in summer months and see temps above 85F and/or potential traffic situations. My car's radiator was fairly new and not leaking, but even at red lights the temp would creep above the midway line and I had to pull over in heavy traffic in 90+ degree weather. Not fun. Scary, knowing how high the risk of a blown HG is on these motors.
                            Of course now it's very cold and the M42 radiator is more than enough, but I still think I would overheat if sitting long enough, there simply is not enough capacity to keep up with an idling 24v motor. I run the 16" spal fan in a puller orientation to boot, it helps but is not enough in hot weather. I plan to upgrade in the spring to an E36 sized mishi or otherwise.
                            • luckysnafu
                              • Jun 2008
                              • 262
                              butters - How are you overheating with your m42 radiator with a 16" puller fan??? I have a 14" pusher fan in front of my m42 radiator and it will keep the temp just above half when sitting in traffic on a summer day. Granted, I have to run my fan on high to keep temps down but I don't know how you would have a problem with a bigger fan in a pulling position.
                              Do you have your fan hooked up to the thermal switch on the radiator?
