24V Radiator Options
  • amcink
    • 788
    I found a Nissen from a e36 4cylinder in great condition (ltsted for leak) at the junkyard for $30. I'm planning to run this
    • iwantspeed
      • 3164
      id recommend a e36 mishimoto radiator,
      I have been running one for about a year
      Project
      Parts for Sale
      Feedback
      YouTube Channel
      • butters
        • 1206
        Originally posted by luckysnafu
        butters - How are you overheating with your m42 radiator with a 16" puller fan??? I have a 14" pusher fan in front of my m42 radiator and it will keep the temp just above half when sitting in traffic on a summer day. Granted, I have to run my fan on high to keep temps down but I don't know how you would have a problem with a bigger fan in a pulling position.
        Do you have your fan hooked up to the thermal switch on the radiator?
        I don't have it hooked up to the switch, I manually turn it on via the a/c button. I realize I don't have "high" this way, but I can imagine how rough the engine would idle if I did run it on a higher voltage.
        • RoadHazard
          • Sep 2007
          • 163
          Sorry for thread jacking but butters, what fan do you run? And how thick is it?
          90 E30 S50B30
          http://www.fquick.com/roadhazard/
          • butters
            • 1206
            I run the very typical SPAL 16 inch "slim" fan mounted on some of Massive's brackets modified to fit the narrower M42 radiator. I think they're only 1" thick?
