s52 swap obd1 Dyno
  • Fernflex
    • 264
    s52 swap obd1 Dyno
    This was done on 91 oct gasoline,87 degrees temp, 40% humidity, No air filter or intake and Flowmeter open to the air.
    All runs 4th gear.
    Motor: (3.2L S52)
    -Bimmerworld 3.5" intake boot
    -Dinan Big Bore TB
    -Bmp Adjustable Regulator
    -Rogue Underdrive Pulley
    -FlowMeter Euro 3.5"
    -M50 Intake Manifold
    -Shrick Cams
    -Injectors 24# Bosch
    -Oscar Velez Tune
    -VAC Motorsports Stage 2 Cylinder Head
    -MLS Gasket .80
    -Head Studs ARP2000
    -Dr.Vanos kit stage1
    -Header Supersprint Euro Rep.
    -Track Pipe Active Autowerke
    -Catback B&B Triflow
    Drivetrain:
    -Clutch UUC M5
    -Flywheel UUC 11.5lbs
    -Diff 3.46
    Please Rate Me:
    http://www.r3vlimited.com/board/show...35#post3283535
    ________________
    1987 332i Track Car (253whp)
    __________________
  • matthugie
    • Mar 2004
    • 1810
    Nice numbers!
    88 325is - S52 powered
    Originally posted by King Arthur
    We'll not risk another frontal assault, that rabbit's dynamite!
    • hoveringuy
      • Dec 2005
      • 2751
      Something is really wrong...
      You go too rich at 5400 and then massively lean at 6200.
      Dangerously lean, perhaps.
      That motor should be hitting 260-265, easy.
      • ak-
        • 12422
        Nice numbers!
        But yeah, your AFR's go turbo status @ 5400 then say oknevermind @ up top. Scary!
        What's stock sized headgasket on s52's?
        1991 325iS turbo
        • Fernflex
          • 264
          I dont know if go with trm chips, stay with a Oscar Velez tune or megasquirt.
          Please Rate Me:
          ________________
          __________________
          • kalib0y
            • Dec 2004
            • 3620
            sweet numbers!
            95 7.1L 16V E36 M3
            Motorsport Hardware ***Wheel studs and Spacers!!!--->FOR SALE 4/5 Lug Stud Conversion Kits available CLICK HERE
            LIKE my Facebook Page! CLICK HERE
            • VinniE30
              • 2113
              I wouldn't be using any "off the shelf" tune with what you have because none of them will match your engine's setup perfectly. Just get it tuned on the dyno by someone good.
              Zinno '89 <24v swap in progress>
              • M-technik-3
                • 18946
                Time to consider either running some bigger injectors with a new tune. Not bad on numbers but there is more to be had.
                • mulletman
                  • May 2012
                  • 801
                  Love the flat torque curve!
                  But yeah, that goes frighteningly lean...
                  • 328ijunkie
                    • May 2007
                    • 3961
                    Put an intake tube back on there. Turbulence at the MAF will cause those AF readings.
                    Check Us out on Facebook
                    Full Product Line Tuning
                    • Fernflex
                      • 264
                      I need to find a 3.5" filter for my car today!
                      Please Rate Me:
                      ________________
                      __________________
                      • MonkeyMan
                        • Jul 2011
                        • 426
                        that thing should easily keep building power on to 7k.. I'm guessing you cut it because of the nasty ping from 6.3k and on?
                        I think a nice fuel upgrade & tune should get you to 280-290whp
                        yummy torque though ;)
                        Make the bastard chase you.
                        • Fernflex
                          • 264
                          What other fuel upgrades could I install?
                          My afpr is running a 42psi in idle, any of you know where ahould it be?
                          Please Rate Me:
                          ________________
                          __________________
                          • 5mall5nail5
                            • 156
                            it should be 3.5 bar with the vacuum line disconnected I believe. Thats around 50 psi. With vacuum, 42-43 psi sounds about right.
                            Find out if its your fuel pump, filter, or what falling off up top. Thats horrible AFR if accurate (and I believe it is given power loss). Also realize that misfires register lean, so its possible you're breaking up at the top end.
                            • Fernflex
                              • 264
                              Any suggestion for good spark plugs?
                              Please Rate Me:
                              ________________
                              __________________
