s52 swap obd1 Dyno
  • 5mall5nail5
    • 156
    BKR6E NGK part number 6962 @ Advanced Auto, etc.
    Gap @ 0.028"
    • hoveringuy
      • Dec 2005
      • 2751
      I'm pretty sure it's the tune, possibly the MAF. It's running pig-rich right before 6200 so your injectors aren't getting maxed.
      My motor looked like that before I fixed the tune and I picked-up close to 20hp when I did.
      • Fernflex
        • 264
        Gap @ 0.028"
        I found them at $2.99 each, thats cheap!
        My old 2007 335 spark plugs cost $20.00 each
        Please Rate Me:
        http://www.r3vlimited.com/board/show...35#post3283535
        ________________
        1987 332i Track Car (253whp)
        __________________
        • etxxz
          • Feb 2006
          • 2085
          gonna say its nice to make 250whp, but your enrichment curve is messed up. Maybe a tad too rich around 5500, but at 6200 it starts to become just dangerous. If anything you want to be even richer there.
          extrapolate/trendfit(eyeballed) your power curve after 6200. you could get another 20hp+ by 7000 with the right fuel curve. Make sure whoever tunes doesnt just do your WOT either. Thanks for sharing though!!
          No more e30s for me.
          88 black BMW OBDII 332is dedicated track [sold]
          88 BMW OBDII bronzit 332is [RIP 03/08]
          91 BMW 325i [sold]
          86 Corolla 'Ae86' HB 20v trd [sold]
          http://youtube.com/watch?v=pTj7Hn9v5Rs
          • e30vince
            • Dec 2012
            • 36
            very very nice hp
            • Fernflex
              • 264
              Gap @ 0.028"
              Is that the gap that spark comes with?
              Please Rate Me:
              ________________
              __________________
              • Fernflex
                • 264
                Update 12/24/12
                I replaced the spark plugs
                Installed:
                K&NCone Filter
                Aluminum Radiator
                And I found the vacumm line from AFPR to the manifold was loose!
                Please Rate Me:
                ________________
                __________________
                • hoveringuy
                  • Dec 2005
                  • 2751
                  Originally posted by Fernflex
                  Update 12/24/12
                  I don't think it was your FPR. Your manifold was close to atmospheric pressure the entire time, the transitions in A/F are much to sudden, plus they go up AND down.
                  I'm betting it's your tune.
                  • ak-
                    • 12422
                    Did you ever fix your tune?
                    1991 325iS turbo
                    • Fernflex
                      • 264
                      Not yet!
                      Please Rate Me:
                      ________________
                      __________________
                      • Fernflex
                        • 264
                        This was done on 91 oct gasoline,87 degrees temp, 40% humidity, No air filter or intake and Flowmeter open to the air.
                        All runs 4th gear.
                        Motor: (3.2L S52)
                        -Bimmerworld 3.5" intake boot
                        -Dinan Big Bore TB
                        -Bmp Adjustable Regulator
                        -Rogue Underdrive Pulley
                        -FlowMeter Euro 3.5"
                        -M50 Intake Manifold
                        -Shrick Cams
                        -Injectors 24# Bosch
                        -Oscar Velez Tune
                        -VAC Motorsports Stage 2 Cylinder Head
                        -MLS Gasket .80
                        -Head Studs ARP2000
                        -Dr.Vanos kit stage1
                        -Header Supersprint Euro Rep.
                        -Track Pipe Active Autowerke
                        -Catback B&B Triflow
                        Drivetrain:
                        -Clutch UUC M5
                        -Flywheel UUC 11.5lbs
                        -Diff 3.46
                        After many months I haven't done too much to the car and discussing with my mechanic when could I take the car to fix some stuff. I told him my speedometer still not working a friend of mine hears me and tells that probably my engine is in limp mode and thats why the graphic is so bad in high rpms.
                        Could this be a reason?
                        The day of this dyno graphic I also had no intake filter and the vacuum line for the afpr was loose.
                        Please Rate Me:
                        ________________
                        __________________
                        • hoveringuy
                          • Dec 2005
                          • 2751
                          Something screwy at 6200 for sure; you're AFR jumps from 11.5 (a little too rich) all the way up to 16. I don't see the FPR doing that so quickly. Tune?
                          • DesertBMW
                            • Aug 2011
                            • 1042
                            Its the worthless euro 3.5" maf. Put the stock instake back on there.
                            • squidmaster
                              • Aug 2011
                              • 2666
                              ^^ agreed
                              or the tune
                              • Fernflex
                                • 264
                                I dont have the stock maf, why do you say it could be the MAF?
                                Please Rate Me:
                                ________________
                                __________________
